Hilux59721707820819 Posted May 21, 2016 Share Posted May 21, 2016 Hi all i have been wondering how sound functions work when double headed in a consist. If 2 steam locos are working together as a consist then do the sound functions work on both locos at once as well? Link to comment Share on other sites More sharing options...
poliss Posted May 21, 2016 Share Posted May 21, 2016 Good question. I have no idea......yet. 😆 Link to comment Share on other sites More sharing options...
96RAF Posted May 22, 2016 Share Posted May 22, 2016 If you are using RM i can confirm TTS decoder sounds will operate independently of each other when in consist. I.e you can toot each horn or whistle to simulate comms between the drivers, etc. the way a consist data is held in memory generally depends upon the decoders, some hold a common address in each decoder memory, some hold a unique address in each decoder memory, and some consists data are generated by the controller, but in RM its the application which holds the consist data so you can even consist decoders that do not support consisting. if controlling from outwith RM then your problem is accessing the sound controls for each loco on the controller, whereas in Rm you can have both controllers on screen (pro pack) at once and press each sound, with both locos under common throttle control. Link to comment Share on other sites More sharing options...
Hilux59721707820819 Posted May 22, 2016 Author Share Posted May 22, 2016 So if im using my Elite it wont work? Link to comment Share on other sites More sharing options...
96RAF Posted May 22, 2016 Share Posted May 22, 2016 I didn't say that - I said if you are controlling from outwith RM your problem is accessing the separate sound functions via your controller. As the Elite has two knobs it should be possible to swap back and forth between them and as you do the associated screen will have the Functions open at the last page each knob used, so why not give it a go and report back telling us how you got on. Link to comment Share on other sites More sharing options...
