pendolino645 Posted May 25, 2016 Share Posted May 25, 2016 I was using my DCC controller(R8213) yesterday when it suddnely turned off and the display went out. I unplugged it from the socket and took the lead out, I left it overnight and it still would not work today. I got the controller in a Hornby Pendolino Digital set. Has the plug fused or is the controller broken?? ☹️ Link to comment Share on other sites More sharing options...
96RAF Posted May 25, 2016 Share Posted May 25, 2016 If you have a meter or even a 12v bulb and some wire you can check if the power supply is working. if it is ok then it looks like the Select may be duff. if its still in warranty take it back. Link to comment Share on other sites More sharing options...
poliss Posted May 25, 2016 Share Posted May 25, 2016 Have you tried it in another mains socket? Link to comment Share on other sites More sharing options...
james_nelmes Posted May 26, 2016 Share Posted May 26, 2016 Same thing happened to mine. I called Hornby and they arranged a repair - took about a week and in my case one of the RF Chokes had failed. Working perfectly now. Link to comment Share on other sites More sharing options...
