Old Bob Posted May 27, 2016 Share Posted May 27, 2016 I need to repair 2 hornby engines both of wich have smoke deflectors broken off (made in china)What adhesive should I use ? Hopefully not super glue ! Link to comment Share on other sites More sharing options...
Buz Posted May 27, 2016 Share Posted May 27, 2016 Hi RLCNormal polystyrene cement should do the job, but pick a brand and style where you can have very good control over the amount of glue dispenced and where it goesregards John Link to comment Share on other sites More sharing options...
Old Bob Posted May 27, 2016 Author Share Posted May 27, 2016 JohnThank for that Will give it a go . Link to comment Share on other sites More sharing options...
trainlover23 Posted May 27, 2016 Share Posted May 27, 2016 Try a good PVA glue as it dries clear and does not mark the body work if it seeps out. Link to comment Share on other sites More sharing options...
Old Bob Posted May 27, 2016 Author Share Posted May 27, 2016 Thanks PVA on the list Am I alone in losing smoke deflectors ? Link to comment Share on other sites More sharing options...
81F Posted May 27, 2016 Share Posted May 27, 2016 I us Mek-Pak the current formulation is a little weaker tham other liquid polystyrene cenent so does not cause so much damage. I would also apply it wit a number 1 brush. You may need several applications but try to keep it away from visible surfaces as it tends to mark. Alternatively Methyl Ethyl Ketone (which some suppliers sell as polystyrne cement) has a stronger "bite" The nice thing about liquid polystyrene cenent is that you can hold the bits together gently and brush over the join and it soaks in. I also use this to build plastic kits. Link to comment Share on other sites More sharing options...
VESPA Posted May 27, 2016 Share Posted May 27, 2016 I doubt if you will find any polysyrene type cements will work. I have experimented with may glues and polystyrene cement, superglue and PVA are all but useless. Get hold of Wilko two pack epoxy resin glue. It will stick almost all plastics and metals and takes quite a while to set (about 30 mins) allowing for any repositioning if required. I use it to permanently fix steps, vac pipes and any other bits. Use it "very sparsely" and leave it to set . DO NOT prod and poke it to see if it had dried. The other glues have the following faults. Polystyrene cement is not suitable for the plastics used by Hornby on their locos. PVA is not strong enough and the joint will break eventually. Superglue may work but will leave white blooming that will need repainting. The two pack needs only a tiny smear and is extremely strong. My other choice of glues is for number and nameplates ONLY and that is Pritt stick. It suitabley sticks the plates very firmly to all my locos and any excess can be washed off with a wet paint brush gently rubbed over any spread under the nameplate leaving no marks. Link to comment Share on other sites More sharing options...
81F Posted May 27, 2016 Share Posted May 27, 2016 Sorry should have said you could always try the Humbrol equivalent@ https://www.humbrol.com/uk-en/shop/adhesives-fillers/poly-cement/liquid-poly-28ml-bottle.html Link to comment Share on other sites More sharing options...
81F Posted May 27, 2016 Share Posted May 27, 2016 I doubt if you will find any polysyrene type cements will work. I have experimented with may glues and polystyrene cement, superglue and PVA are all but useless. Get hold of Wilko two pack epoxy resin glue. It will stick almost all plastics and metals and takes quite a while to set (about 30 mins) allowing for any repositioning if required. I use it to permanently fix steps, vac pipes and any other bits. Use it "very sparsely" and leave it to set . DO NOT prod and poke it to see if it had dried. The other glues have the following faults. Polystyrene cement is not suitable for the plastics used by Hornby on their locos. PVA is not strong enough and the joint will break eventually. Superglue may work but will leave white blooming that will need repainting. The two pack needs only a tiny smear and is extremely strong. My other choice of glues is for number and nameplates ONLY and that is Pritt stick. It suitabley sticks the plates very firmly to all my locos and any excess can be washed off with a wet paint brush gently rubbed over any spread under the nameplate leaving no marks.Hi Vespa I find it depends n the loco (and possibly when it was made) most of the newer ones like the GWR Star or Railroad Couty (both types) and ex Dapol Castle will take liquid poly cement. graned you may need a couple of attempts. Having said that the older Triang plastic is a lot less forgiving and the bond is weak. Also thee is no hope with the rubbery or slightly flexible plasics used on underframes. Link to comment Share on other sites More sharing options...
Old Bob Posted May 27, 2016 Author Share Posted May 27, 2016 Thanks guys for all your info The engines by the way are recent made in china issues. Link to comment Share on other sites More sharing options...
VESPA Posted May 27, 2016 Share Posted May 27, 2016 I have just succesfully detailed 3 Britannias and noticed that the latest versions have the front steps already fitted. I tried using poly cement on the draincocks but the following day came away so went back to two pack. Perhaps these models are now being made in different factories with different plastics if poly cement works on some but not others. I think I will stay with my tried and tested method just in case. Link to comment Share on other sites More sharing options...
poliss Posted May 27, 2016 Share Posted May 27, 2016 Polystyrene cement only works on polystyrene. It melts the plastic to form a bond.If I want something to stick permanently I use two part epoxy. Link to comment Share on other sites More sharing options...
81F Posted May 27, 2016 Share Posted May 27, 2016 I have just succesfully detailed 3 Britannias and noticed that the latest versions have the front steps already fitted. I tried using poly cement on the draincocks but the following day came away so went back to two pack. Perhaps these models are now being made in different factories with different plastics if poly cement works on some but not others. I think I will stay with my tried and tested method just in case.Ah that explains it, I think the drain coxks oe cyliners might be that flexible plastic I mentioned.The ones that came with m 42XX seemed to be but fortunately they are a tigt fit - just hope smoke deflectors are not mae of the same stuff. Link to comment Share on other sites More sharing options...
