Paul60 Posted May 29, 2016 Share Posted May 29, 2016 Hi all, On both my Elite & Select, my DDC Ready Loco runs forward when the direction indicator arrow points left. I assume I must have put the Sapphire controller in the wrong way round ? It would seem logical that the loco would go forward when the arrow points to the right ? Only just noticed. Not keen to open it up if not necessary. Is that right or wrong ? Cheers :) Link to comment Share on other sites More sharing options...
Hairy Posted May 29, 2016 Share Posted May 29, 2016 Hi Paul, the arrow does indeed point to the left for forward running, so you have installed your sapphire decoder the correct way round.Chris Link to comment Share on other sites More sharing options...
Paul60 Posted May 29, 2016 Author Share Posted May 29, 2016 Thanks Chris, Much appreciated. 😀 Link to comment Share on other sites More sharing options...
walkingthedog Posted May 29, 2016 Share Posted May 29, 2016 I thought DCC locos always travelled front end first when forward was selected which ever way the loco is pointing. Link to comment Share on other sites More sharing options...
poliss Posted May 29, 2016 Share Posted May 29, 2016 Forward can be any way you want it to be. If you want your locos to go forward when you press the right arrow you just alter the default direction by following the instructions in the manual. No need to open anything up. The only time you'd need to open up a loco would be if the rear lights were on when the loco was going forward, or vice versa. Link to comment Share on other sites More sharing options...
Hairy Posted May 29, 2016 Share Posted May 29, 2016 I thought DCC locos always travelled front end first when forward was selected which ever way the loco is pointing. Hi WTD, Try telling my GWR class 42xx that. It came factory fitted with a decoder fitted, but ran backwards when it was supposed to run forwards 😮.Whether it was an incorrectly fitted decoder or crossed wires from the decoder to the motor, I don't know as i haven't opened it up to check. All I did was to add 1 to the value in CV29 to change the direction, simple really.RegardsChris 😀 Link to comment Share on other sites More sharing options...
Paul60 Posted May 29, 2016 Author Share Posted May 29, 2016 I meant 'relative' to the arrow on the controller. By default, my loco runs forward when the arrow points left. I thought the default direction would be arrow to right. Anyway.... Thanks again Chris. Link to comment Share on other sites More sharing options...
walkingthedog Posted May 29, 2016 Share Posted May 29, 2016 That's what I thought, you decide which way is forward digitally. Link to comment Share on other sites More sharing options...
poliss Posted May 29, 2016 Share Posted May 29, 2016 In the UK, when you enter a station, trains usually move to the left on the closest track to you. Link to comment Share on other sites More sharing options...
Paul60 Posted May 29, 2016 Author Share Posted May 29, 2016 Well, All I can say is, thank god we don't have an Up & Down to contend with eh ? 😀 Link to comment Share on other sites More sharing options...
poliss Posted May 29, 2016 Share Posted May 29, 2016 The arrows on my controller point up and down as well as right and left. 😆 Link to comment Share on other sites More sharing options...
walkingthedog Posted May 29, 2016 Share Posted May 29, 2016 Do you have a digital gradient on your layout poliss? Select the up arrow and the train gracefully climbs at 1 in 30 😀 Link to comment Share on other sites More sharing options...
poliss Posted May 29, 2016 Share Posted May 29, 2016 Be useful for a maglev train. 🤐 Link to comment Share on other sites More sharing options...
96RAF Posted May 29, 2016 Share Posted May 29, 2016 This direction button topic is clearly discussed in the Elite and Select and RM manuals from memory, including what to do if you want to have it tother way round. Link to comment Share on other sites More sharing options...
Paul60 Posted May 30, 2016 Author Share Posted May 30, 2016 This direction button topic is clearly discussed in the Elite and Select and RM manuals from memory, including what to do if you want to have it tother way round. I must make more effort to read instructions and manuals. I am very slack like that. 😀 Link to comment Share on other sites More sharing options...
