edward_caudy Posted June 5, 2016 Share Posted June 5, 2016 How do I convert old Zero 1 ready locos to dcc ? I have a few trains with zero 1 but want to change them to dcc . My favourite is the 2-4-4 LMS 4T but not sure how to convert it Link to comment Share on other sites More sharing options...
poliss Posted June 5, 2016 Share Posted June 5, 2016 You have the instruction sheet on how to convert them to Zero 1 originally? You need to reverse the process and then follow the process for converting them to DCC. Link to comment Share on other sites More sharing options...
Fishmanoz Posted June 5, 2016 Share Posted June 5, 2016 Can't find details of your loco, but in the absence of the instruction sheet poliss mentioned it's simple in principle. Remove all wiring, components and connections except the wires coming from the pickups. If more than one wire from either side pickups, solder their ends together. If there is a pickup connection to chassis, and a motor connection to chassis, you must isolate them so no motor connection to chassis. Now solder decoder red to pickup wires on one side and decoder black to the other. Finally, solder decoder orange and grey to the motor connections. Test before reassembly and, if loco runs backwards to what you want, swap orange and grey. Link to comment Share on other sites More sharing options...
