Repairs
Tigg
Hi All,
I'm currently repairing R214 (Castle Donnington Power Station 0-4-0 shunter). The propshaft won't connect to the drive cog and the motor isn't wired to the pick-ups.
Re the cogs, ideas went from getting a bigger drive cog that will reach to the proshaft cog - but that will mean having to remove the wheels/axles to fit it - to adjusting the motor mounting, but since the rear drive wheel axle seems to run through the mounting, that idea didn't seem practical.
Re the lack of wiring, should the wires be soldered directly to the pick-ups? If so, which wires go to which pick-ups?
Any guidence in this would be most appriciated.
P.S. Are there any tools available to remove the coupling rods/crank pins and the driving wheels?
Thanks.
I'm not familiar with this particular model, but if the coupling rods are held on by Hornby Hex headed micro bolts, then they are likely to be 12BA. A 12BA (2.5mm) Nut Spinner can be purchased from Expo tools.
Thanks for that.
I've had a look and the bolts are 3mm diameter and are circular in shape. Is there anythink to remove those?
I wouldn't like to say ya or nay, but I think that the round coupling rod fixings are maybe not bolts but press fit securing pins. Your model may be one of these Hornby Service Sheets. None of the 0-4-0 loco chassis sheets below specifically mention your R214 model number, but they all show predominantly the same round pin coupling fixing pin arrangement. I included the 200 series sheets for completeness of information, but I think that those are dated probably too recently (1997 - 2008) for your model R number.
HSS082
HSS082A
HSS115
HSS115A
HSS200
HSS200B
HSS200C
HSS200D
HSS200E
PS - Just had a closer look at HSS082, the parts list documents the coupling pin as a screw. But the HSS115 documents it as a pin. Take your pick.
HSS082
HSS082A
HSS115
HSS115A
HSS200
HSS200B
HSS200C
HSS200D
HSS200E
Thanks for that. Most helpful.
So, if they are the pins in question, which it looks like they are, what would be the best/most appropriate tool for removing them from the coupling rod & wheels?
Thanks again.
HSS082
HSS082A
HSS115
HSS115A
HSS200
HSS200B
HSS200C
HSS200D
HSS200E
