Waztot Posted June 19, 2016 Share Posted June 19, 2016 Hi guys and gals, my railmaster/elite combination was working fine until yesterday. I updated my elite to v1.42 and now my railmaster will set the locos in motion but won't slow down or stop them. The only way to stop them is using the emergency stop button on elite. The elite controls them absolutely fine.HELP Link to comment Share on other sites More sharing options...
96RAF Posted June 19, 2016 Share Posted June 19, 2016 Restart the Elite and you will probably find it is starting into Classic mode after the update. Change it back to Standard mode from the Elite Menu button and you should be OK with RM again. Link to comment Share on other sites More sharing options...
Chrissaf Posted June 19, 2016 Share Posted June 19, 2016 Change it back to Standard mode from the Elite Menu button..Waztot, see page 67 of the latest Elite user guide. Link to comment Share on other sites More sharing options...
Waztot Posted June 19, 2016 Author Share Posted June 19, 2016 Thanks guys will try that although I'm pretty sure it is in standard mode Link to comment Share on other sites More sharing options...
Waztot Posted June 19, 2016 Author Share Posted June 19, 2016 Hi guys have checked and it is definitely in standard mode. All controls from elite work fine but on railmaster the point controls etc work fine, the accelerate works fine and the pause button stops the trains but if you reduce the throttle it has absolutely no effect neither has the stop button on screen. Any more ideas Link to comment Share on other sites More sharing options...
poliss Posted June 19, 2016 Share Posted June 19, 2016 Have you tried restetting it? Link to comment Share on other sites More sharing options...
96RAF Posted June 19, 2016 Share Posted June 19, 2016 There is an unresolved problem with RM second large throttle not working properly when scale speed is enabled. try selecting this on and off. Link to comment Share on other sites More sharing options...
Fishmanoz Posted June 19, 2016 Share Posted June 19, 2016 Oops, my point already covered, ignore. Link to comment Share on other sites More sharing options...
