Hecla Posted November 19, 2011 Share Posted November 19, 2011 I've recently bought a Thompson L1 as DCC ready, but, now realise I need to buy and fit a chip to convert to a DCC fitted loco. Any instruction or adcise would be greatly welcomed.Cheers,Ron. Link to comment Share on other sites More sharing options...
Flashbang Posted November 19, 2011 Share Posted November 19, 2011 HiCarefully remove locos body. |Remove small 8 pin plug-in Blanking plug form socket and keep for possible future use. Plug the 8 pin plug from chosen decoder into the now free 8 pin socket. Ensure Pin 1 matches the mark on the locos main circuit board. Fix decoder in position ensuring it cannot make contact to anything metal, tidy decoder wires ensuring they can not be trapped when the body is refitted. Place loco on programming track and set it address to that require. Its supplied as 3 so you really should select another number. Chose a number from 1 up to the number maximum of the DCC system (Select is form 1 to 59, while the Elite is from 1 to 9999). Test loco on power track and assuming all is ok refit body.Job done :-) Link to comment Share on other sites More sharing options...
Hecla Posted November 20, 2011 Author Share Posted November 20, 2011 Brilliant. Thanks for that. I appreciate your knowledge. Thanks.Ron.Flashbang said:HiCarefully remove locos body. |Remove small 8 pin plug-in Blanking plug form socket and keep for possible future use. Plug the 8 pin plug from chosen decoder into the now free 8 pin socket. Ensure Pin 1 matches the mark on the locos main circuit board. Fix decoder in position ensuring it cannot make contact to anything metal, tidy decoder wires ensuring they can not be trapped when the body is refitted. Place loco on programming track and set it address to that require. Its supplied as 3 so you really should select another number. Chose a number from 1 up to the number maximum of the DCC system (Select is form 1 to 59, while the Elite is from 1 to 9999). Test loco on power track and assuming all is ok refit body.Job done :-) Link to comment Share on other sites More sharing options...
