minoo Posted July 14, 2016 Share Posted July 14, 2016 Hi guys,Keenly interested in having R1184 Hornby Western Express digital train set with eLink with TTS sound Hall steam loco Wanted to know about the performance of the loco, the details of the pullman coaches and functionality of E linkI have a Roco z21 with multimaus controller so will E link be compatible to use with my laptop which has windows vistaThanks for the replies (in advance)Minoo Link to comment Share on other sites More sharing options...
Bigskybirds Posted July 14, 2016 Share Posted July 14, 2016 Hi MinooI recently purchased the Western Express from Hattons, Ketley Hall is a nice Railroad model and has good haulage ability. The pullman coaches are basic Railroad models with white roofs but on the track behind the loco they look very nice. I purchased the set for the locomotive only and sold off the elink and coaches so the loco and track only cost me £40. The TTS sound is loud even at setting 1, but for the price I paid I will use it on DC I have too many locos to switch permanently to DCC. I will let others answer the elink question's since I prefer a non pc attached controller. Link to comment Share on other sites More sharing options...
96RAF Posted July 14, 2016 Share Posted July 14, 2016 @bsbyou do realise that although you can control the motor of a TTS loco on dc the manual makes note that the sound will not work, so you may as well remove the decoder and flog it as well. Link to comment Share on other sites More sharing options...
Chrissaf Posted July 14, 2016 Share Posted July 14, 2016 eLink and RailMaster is totally compatible with Windows Vista. You do realise that you must either use the RM / eLink combo OR your Roco Z21. You can't use them both together on the same layout. The TTS Hall should work with any NMRA compliant controller supporting the function range from F0 up to F24..eLink is just the track interface for RailMaster. Therefore, to understand what the functionality of the eLink is, you only need to read the RailMaster User Manual - click the link to view and/or download. Link to comment Share on other sites More sharing options...
Bigskybirds Posted July 14, 2016 Share Posted July 14, 2016 @RAF96My layout does have two DCC switchable running tracks but I only use them now to test locos. I will leave the TTS in place to keep the model to the spec it was meant to be, but you are right it could be taken out and sold and if I did that I would probably be in profit :-) Link to comment Share on other sites More sharing options...
Bigskybirds Posted July 14, 2016 Share Posted July 14, 2016 @MinooHere is the Ketley Hall running on my layout, you can view the coaches and hear the TTS sound. Go to 4 mins in.https://youtu.be/RnmS1ambq7U Link to comment Share on other sites More sharing options...
minoo Posted July 15, 2016 Author Share Posted July 15, 2016 Guys,Thanks for the response. 😆 The video was impressive and has now instilled the confidence to get the set. 😮 I also now understand that although the train can be controlled by z21, the z21 cannot be linked with Elink.Appreciate your replies and clarifications. At 125 GBP from Hattons, it is a steal!!!!Regardsminoo Link to comment Share on other sites More sharing options...
Fishmanoz Posted July 15, 2016 Share Posted July 15, 2016 Z21 and eLink will certainly not connect together, they are both DCC controllers and you can only have one controller connected to any DCC track. Of more relevance, you cannot connect the z21 to RM on your PC. Link to comment Share on other sites More sharing options...
Fozzy Bear Posted July 16, 2016 Share Posted July 16, 2016 I would suggest to have RM control all the points etc and a DPDT switch to make the track supply only selectable from either RM or the z21. Link to comment Share on other sites More sharing options...
minoo Posted July 19, 2016 Author Share Posted July 19, 2016 Thanks once again for the recent replies and apologies for not replying earlier. Link to comment Share on other sites More sharing options...
