peter _murray Posted July 18, 2016 Share Posted July 18, 2016 I am using an elink control system an Hornby insult frog points. I wish to use the cobalt ip digital to isolate a rail so that trains cannot run the points. I have done this with a cobalt before using the built in switches. Can I use the "frog" outlet (3) from the ip digital to do the same thing. All the information I can find only talks about it being used for frog polarity. If I can how do I determine the polarity of what is delivered from this terminal. I.e. A or B as per the terminals on the track terminals of the elink. I do not wish to use the onboard switch as I want that for changing signal lights. Link to comment Share on other sites More sharing options...
Flashbang Posted July 18, 2016 Share Posted July 18, 2016 AFAIK you cannot do as you're thinking. T3 swaps polarity and even if both rails (one isolated and live) are at the same polarity a short would occur as soon a s a metal wheel bridged the out of phase isolation. Only way it to completely remove the power from the isolated rail making a totally dead rail section.. Do this use a relay driven form the actual contacts of the Cobalt and use one set of the relays contacts for signalling and the other for the rail isolation/feed Link to comment Share on other sites More sharing options...
Chrissaf Posted July 18, 2016 Share Posted July 18, 2016 FB is correct regarding terminal 3 on the IP Digital. In essence terminals 1, 2 & 3 are the three terminals of a single pole change-over relay contact, but as terminals 1 & 2 are also the power input, whether that be DC or DCC then the output on terminal 3 will be either one input condition or the other. You can't separate terminals 1 & 2 from the power connection for use as a general purpose relay contact. Parallel a slave relay to the separate IP Digital c/o contacts if you need more contact functions. Link to comment Share on other sites More sharing options...
peter _murray Posted July 18, 2016 Author Share Posted July 18, 2016 Thanks for replies, relay seems the way to go. I have a few in the drawer so will experiment. Link to comment Share on other sites More sharing options...
