sam_penton Posted August 13, 2016 Share Posted August 13, 2016 hellodoes anyone know the how to convert dcc ready trains to dcc preferably without paying a specialist to do it? Link to comment Share on other sites More sharing options...
RB51 Posted August 13, 2016 Share Posted August 13, 2016 Hi Sam, if your loco is DCC ready it will have a socket already installed but with a DC plug in it, known as a blanking plug. Just, carefully, take that out and instal a decoder of your choice. No need to pay anyone else. R- Link to comment Share on other sites More sharing options...
96RAF Posted August 13, 2016 Share Posted August 13, 2016 Remove the body, remove the DCC blanking plug and plug in the decoder.Test and refit the body. Problem is you have to know which type of decoder you need, usually a choice between 8 or 21 pin. THis will be indicated on the box or in the instructions That come with the loco. Some locos may require 2 decoders , eg DMU or EMU. edit - beaten to it by Rog... Link to comment Share on other sites More sharing options...
poliss Posted August 13, 2016 Share Posted August 13, 2016 The hardest part is usually finding how to take the body off the loco. Link to comment Share on other sites More sharing options...
81F Posted August 16, 2016 Share Posted August 16, 2016 I would also add that some manufacturers have started to use 6 pin decders as well. In some smaller locos it's easy to plug the chip in but getting the body back together can be challenging. What locos do you have in mind? Some of the easiest I've done have been the Hornby Star, Hall and County and other Railroad 4-4-0s where the 8 pin chip is in the tender Link to comment Share on other sites More sharing options...
ModelerXYZ Posted September 2, 2016 Share Posted September 2, 2016 instructions for converting a DCC ready loco:1. Take out of box or off track2. Open body3. Locate blanking chip4. Remove blanking chip (usually 8 pin chip)5. Plug decoder in where blanking chip was.6. Test as number 03 on digital system.7. Close bodyshell8. Program as other number. No Loco should be assigned as 3.Play trains. Use only Digital trains on a digital system. XYZ Link to comment Share on other sites More sharing options...
