Jimbo1707820979 Posted August 16, 2016 Share Posted August 16, 2016 Hello AllJust thought I would warn of possible dire consequences (decoder burn-out) when using the Gaugemaster GM60, base on my recent nasty experience.I was cleaning the wheels of my newly acquired "Lion", using 2 xGM60 clipped together, as recommended to accommodate a longer loco. Suddenly there was bright spark. Yikes ! Turns out that the "bright spark" wasn't me ! 🤐 and I must have caused a short-circuit through careless handling. Easy to do with a multiple wheeled engine.The GM60 is an excellent bit of kit which I have found really convenient. But be careful if you are cleaning a CoCo or similar with a bunch of wheels as the wheels sometimes not easy to see behind the skirting, or whatever it's called. Link to comment Share on other sites More sharing options...
poliss Posted August 16, 2016 Share Posted August 16, 2016 I use the Tsugawa Yokou wheel cleaner. Smooth, not scratchy. Gaugemaster sell it as the GM50 for 00 gauge. Link to comment Share on other sites More sharing options...
96RAF Posted August 16, 2016 Share Posted August 16, 2016 I have a GM60 and so far I have never seen that problem but I can see how the brass brushes could short on any vulnerable areas of the loco. Link to comment Share on other sites More sharing options...
