stevieedge Posted August 22, 2016 Share Posted August 22, 2016 Have just upgraded to pro packageIs it possible to run more than 1 programme at a timeI thought the hot buttons might have allowed but whilst you can set each button for a different programme when you click on a second button the previous programme stops runningany advise welcoeI know you can merge programmes but that is not quite what I was after Link to comment Share on other sites More sharing options...
RDS Posted August 22, 2016 Share Posted August 22, 2016 No, you can only run 1 program at once. Link to comment Share on other sites More sharing options...
Fishmanoz Posted August 22, 2016 Share Posted August 22, 2016 Check out the Chain command and see if that helps. Link to comment Share on other sites More sharing options...
stevieedge Posted August 23, 2016 Author Share Posted August 23, 2016 I think the chain command is as close as i can get thanks Link to comment Share on other sites More sharing options...
