cowside Posted August 23, 2016 Share Posted August 23, 2016 As I can't find a Hornby GWR 45xx tank I bought a Bachmann version, and fitted the Hornby R8249 decoder. This engine is not on the Railmaster list so I have selected it as a GWR 51xx tank. The 45xx works fine, but the scale speeds are wrong - for example, 50mph seems like a crawl. I suspect this is because Railmaster settings are based on the 51xx having bigger wheels. Any ideas what settings to use for the 45xx? I have no problems programming the CV parameters if that is what is needed! Link to comment Share on other sites More sharing options...
walkingthedog Posted August 23, 2016 Share Posted August 23, 2016 Can you find a loco with similar sized wheels. Link to comment Share on other sites More sharing options...
Chrissaf Posted August 23, 2016 Share Posted August 23, 2016 Look in the current version 1.64 RM manual page 36. The bottom half of the page discusses the option to set scale speeds for non Hornby locos. If you amend (via experimentation) the "Time to travel..........." distance setting. This may give you the effect on speed you are after. This is a RM setting, so does not AFAIK require CVs to be changed. Link to comment Share on other sites More sharing options...
aj2010 Posted August 23, 2016 Share Posted August 23, 2016 . Link to comment Share on other sites More sharing options...
cowside Posted August 24, 2016 Author Share Posted August 24, 2016 Thank you for your replies. Some avenues to pursue! Link to comment Share on other sites More sharing options...
