DMU mad Posted August 28, 2016 Share Posted August 28, 2016 Hello all! I've been out of the hobby for about a year or two, but have recently set everything back up and running. Track is clean and all locos run perfectly except my 153. It's DCC fitted, however it doesn't run smoothly at all. Instead, it's very jumpy and seems to be quite fast when setting off. I've cleaned the track and the wheels, oiled the necessary parts and checked the wiring inside as well as the decoder itself, all to no avail. It hasn't been used in about a year and a half, but before that it was running perfectly. Any suggestions?-Eden0032 Link to comment Share on other sites More sharing options...
poliss Posted August 28, 2016 Share Posted August 28, 2016 What controller do you have? Does the decoder support CVs 2,6 and 5? Link to comment Share on other sites More sharing options...
DMU mad Posted August 28, 2016 Author Share Posted August 28, 2016 What controller do you have? Does the decoder support CVs 2,6 and 5?It's a Hornby 8 pin decoder, and I'm using the blue brand wireless controller that we all know the name of! ;) Link to comment Share on other sites More sharing options...
poliss Posted August 28, 2016 Share Posted August 28, 2016 The standard Hornby decoder doesn't support the CVs that can help with smoother running.Do you have another decoder you could try? Link to comment Share on other sites More sharing options...
DMU mad Posted August 28, 2016 Author Share Posted August 28, 2016 The standard Hornby decoder doesn't support the CVs that can help with smoother running.Do you have another decoder you could try?I dont have any other decoders unfortunately. It never used to be like this, so cant understand what night have changed! Link to comment Share on other sites More sharing options...
poliss Posted August 28, 2016 Share Posted August 28, 2016 Have you tried resetting the decoder by writing 8 to CV8? Link to comment Share on other sites More sharing options...
58001 Posted August 28, 2016 Share Posted August 28, 2016 I agree, resetting the decoder often gets rid of this sort of behaviour. Link to comment Share on other sites More sharing options...
DMU mad Posted August 29, 2016 Author Share Posted August 29, 2016 Thanks for the replies. I've set CV8 to 8, as well as CV3 and CV 4 (acceleration and deceleration) to 30, and unfortunately it's still jumping. I've noticed that it only seems to be the first speed step. I'm running it on a fairly small layout so will only be using the first 3 or 4 speed steps, hence why it is crucial that it runs smoothly at these slow speeds. Are there any other tips that I could try to get it to run a bit smoother like it used to? Link to comment Share on other sites More sharing options...
DMU mad Posted August 29, 2016 Author Share Posted August 29, 2016 After fiddling around with some of the other CV's I've managed to fix it! Turns out it was a decoder from the "other brand" after all, and lowering the value of CV 54 sorted it. I also increased CV55 and reduced CV 5 (max voltage) for better running conditions. Thanks for the assistance! Link to comment Share on other sites More sharing options...
Fishmanoz Posted August 29, 2016 Share Posted August 29, 2016 There are particular Bachmann decoder type/s well known for this and there is a Bachmann guide on how to adjust the CVs mentioned to fix it. Link to comment Share on other sites More sharing options...
96RAF Posted August 29, 2016 Share Posted August 29, 2016 The quality of the help available on this forum is directly proportional to the information supplied as a clue to the problem. ....gospel according to St Rob Ch 3, verse 6. Link to comment Share on other sites More sharing options...
