DavidT Posted August 31, 2016 Share Posted August 31, 2016 Hi all, having problems addressing Cobolt decoders using Railmaster? have tried deleting and reinstalled turnout on track plan but still cannot get it to address? have tried replacing with another , same issue will not address, is there anyway of checking decoder for faults apart from changing and trying another decoder. I am addressing as per DCC instructions for screen based systems.Thanks for any help. Link to comment Share on other sites More sharing options...
St1ngr4y Posted August 31, 2016 Share Posted August 31, 2016 Are you switching each port to learn mode then clicking the point button on your layout diagram then switching it back to operational?Ray Link to comment Share on other sites More sharing options...
DavidT Posted August 31, 2016 Author Share Posted August 31, 2016 Are you switching each port to learn mode then clicking the point button on your layout diagram then switching it back to operational?Ray Link to comment Share on other sites More sharing options...
St1ngr4y Posted August 31, 2016 Share Posted August 31, 2016 Type a message in the box below and press the green Reply button Link to comment Share on other sites More sharing options...
DavidT Posted August 31, 2016 Author Share Posted August 31, 2016 Thanks Ray , i assume you mean to use learn mode on the on screen display and not the track diagram?Thanks Link to comment Share on other sites More sharing options...
St1ngr4y Posted August 31, 2016 Share Posted August 31, 2016 No David. On the ADS2FX decoder, there are two ports i.e. 2 sets of electronics, and each one has a "learn" switch - a slider type switch. The instructions on the packaging will tell you which is the learn position. So, move one of these switches to the learn position. Then on the Raimaster screen, click the button for that point. Then switch the decoder switch back to operational. Then go back to the Railmaster screen. Alternately clicking the green and red buttons should then switch the point back and forth. Then repeat the process for the second port on the decoder.Ray Link to comment Share on other sites More sharing options...
Fishmanoz Posted August 31, 2016 Share Posted August 31, 2016 These are the simplest of decoders to program. All you do is switch to learn, operate the point you want it to control on the RM screen and switch the decoder switch back to run. Just as Ray says, it's now done. They are so simple, chances are you are overthinking it. Link to comment Share on other sites More sharing options...
DavidT Posted September 1, 2016 Author Share Posted September 1, 2016 Thanks for this instruction, have done as suggested but still cannot get points to operate, should i be checking other issues? The RM screen does show the point switching ie, the grey inner line on screen at point does move but point doesnt move physically? Thanks for contiued assistance.David Link to comment Share on other sites More sharing options...
Yelrow Posted September 1, 2016 Share Posted September 1, 2016 quite often point motors get screwed down too tightly. I test each point motor, loose on layout before i attempt to fix. That way i know it works. john Link to comment Share on other sites More sharing options...
St1ngr4y Posted September 1, 2016 Share Posted September 1, 2016 Thanks for this instruction, have done as suggested but still cannot get points to operate, should i be checking other issues? The RM screen does show the point switching ie, the grey inner line on screen at point does move but point doesnt move physically? Thanks for contiued assistance.DavidHi David,What kind of point motors are you using? Make sure the three wires from the point motor are going to the correct terminals on the decoder - i.e. the common return should go to the centre of the three terminals on the decoder. Also, provided you have the two DCC wires connected to the decoder, then you can test the decoder-to-point operation using the three terminals marked "Momentary". You can do it with a piece of wire in a U shape. Touch the two legs of the U against the left and centre of the Momentary terminals and the point should fire. Touch the right and center of the Momentary terminals and the point should fire the other way.Ray Link to comment Share on other sites More sharing options...
DavidT Posted September 2, 2016 Author Share Posted September 2, 2016 Thank you John, i have checked as suggested and tried the point motor loose still same problem will not switch still not 100% about the decoder working correctly.David Link to comment Share on other sites More sharing options...
DavidT Posted September 2, 2016 Author Share Posted September 2, 2016 Thank you Ray will try this.David Link to comment Share on other sites More sharing options...
DavidT Posted September 2, 2016 Author Share Posted September 2, 2016 Hi Ray, have now tried test using momentary terminal ,still no response at point motor ?David Link to comment Share on other sites More sharing options...
St1ngr4y Posted September 2, 2016 Share Posted September 2, 2016 Hi Ray, have now tried test using momentary terminal ,still no response at point motor ?David... and the DCC supply is connected to the decoder also? Link to comment Share on other sites More sharing options...
DavidT Posted September 2, 2016 Author Share Posted September 2, 2016 Yes DCC supply connected.David Link to comment Share on other sites More sharing options...
St1ngr4y Posted September 2, 2016 Share Posted September 2, 2016 Have you either .....a means of testing the point motor independent of the decoder i.e. a 16v ac supplyora multimeter to test the outputs marked Solenoid on the decoderRay Link to comment Share on other sites More sharing options...
DavidT Posted September 6, 2016 Author Share Posted September 6, 2016 Thanks everyone, have been intouch with DCC concepts who are being very helpful with my problem. So hopfully will get it sorted very soon. Link to comment Share on other sites More sharing options...
