stevieedge Posted September 18, 2016 Share Posted September 18, 2016 this is my first layout and I have made a few mistakes, my main problem is getting the points to work properlyAll my wiring to the points is within the foam of the model so its impossible to change.all the wiring has been checked and has good continuity but the power drop on the runs wont power 2 surface mounted soleniods.I am using a dcc concepts decoder which clearly states its easily capable of firing 2 together but they also reccomend using a certain size wire. which in ignorance I did not. It fires one solenoid very positevly but not 2. If I remove the little spring wire under the plastic cover on both points it will power the points but they dont snap into position and tend to spring back a little from the side of the rail. has any body got any suggestions as how I can get over this as I have 7 pairs of points. Link to comment Share on other sites More sharing options...
Gitter Posted September 18, 2016 Share Posted September 18, 2016 hi stevie, could you let the knowledgable people know what your set-up is . controller , railmaster? and whatever, . It's all relevant. No doubt they will be on after Sunday breakfast. Link to comment Share on other sites More sharing options...
stevieedge Posted September 18, 2016 Author Share Posted September 18, 2016 railmasterelink4amp power supplyColbalt ADS-8FX DecodersHornby pointshornby surface point motorsprobably 25 foot runs of 6 core alarm cables but dont know actual sizeI hope there is an easy fix with wiring but fear not. Is there any way to make the points more positive when the little spring has been removed Link to comment Share on other sites More sharing options...
stevieedge Posted September 18, 2016 Author Share Posted September 18, 2016 just a bit more on the cablesif i use 3 wires for one motor it works fine when i try to use 3 wires to fire 2 motors probably one the first in line will fire but with not such a positive click of the solenoidhope thats understandable Link to comment Share on other sites More sharing options...
Chrissaf Posted September 18, 2016 Share Posted September 18, 2016 probably 25 foot runs of 6 core alarm cables but dont know actual size.I've installed Alarms and used this cable. The CSA (Cross Sectional Area) is 0.22mm2 this is very small and in my view totally unsuitable for the high current requirement of a solenoid point motor. You say re-cabling is impossible, but again in my view this is the only practical resolution. There must be some way of finding a route to the point, even if not using the one you previously used. Can you not use the alarm cable to pull in the thicker replacements (remember you need three wires of about CSA 1.0mm2 each)..PS - 24/0.2mm wire is equivalent to CSA 0.75mm2 Link to comment Share on other sites More sharing options...
Fozzy Bear Posted September 18, 2016 Share Posted September 18, 2016 What Chris said, and put the spring back or the points will never be any good. They will always pop back open a little bit Link to comment Share on other sites More sharing options...
96RAF Posted September 18, 2016 Share Posted September 18, 2016 Ive used cat5 network cable pairs to wire doubled up point motors including the little black ones with great success over several metres. I dont know the exact csa of these solid wires though. Link to comment Share on other sites More sharing options...
Chrissaf Posted September 18, 2016 Share Posted September 18, 2016 Their diameter is 0.63mm, if Area = Pi x r2, then CSA = 0.312mm2 Link to comment Share on other sites More sharing options...
walkingthedog Posted September 18, 2016 Share Posted September 18, 2016 When you say the wiring is in the foam, what type of foam? Link to comment Share on other sites More sharing options...
NormanQ4 Posted September 18, 2016 Share Posted September 18, 2016 Expanded or extruded polystyrene foam is incompatible with the PVC insulation of electrical wire.Over time the polystyrene will eat away the PVC insulation.To avoid this you have to create separation between the two by using a membrane.A simple method that I use is to wrap the cable in regular paper masking tape where it passes through the foam or any place that they may touch. Link to comment Share on other sites More sharing options...
walkingthedog Posted September 18, 2016 Share Posted September 18, 2016 That's why I asked Norman, and it is amazing how quickly it affects the insulation. Link to comment Share on other sites More sharing options...
stevieedge Posted September 18, 2016 Author Share Posted September 18, 2016 Thanks for all the advise,unfortunately it does not sound goodThe cabling is sandwiched between polystyrene sheets and is in contact with the sheets. have been looking up the problems of pvc cables in polystyrene to get an idea of time. but it is not very clear as to time scalefrom your comments it does look like i may have to find alternative routes to the points and keep an eye on the other lighting cables, as i understand the problem is the plasticisers leech out of the cables and they then can become brittle. the only reference i can find is talking in terms as a reduction in the numder of years the cable has before it goes brittle, has anyone got a better idea of how long it might survive. ie 6 months 1 year 2 years 5 yearrs.the initial cables were put in appox 4 months ago and i cant see or feel any change as of yet Link to comment Share on other sites More sharing options...
walkingthedog Posted September 18, 2016 Share Posted September 18, 2016 I got to know about the problem fitting out a narrow boat. We had to wrap all cables in masking tape where they touched polystyrene that was used for insulation. I believe the problem could occur fairly quickly, say 6 months or it could be years. The trouble is the cable looks OK but crumbles when touched or moved. Link to comment Share on other sites More sharing options...
RDS Posted September 18, 2016 Share Posted September 18, 2016 I had problems right from start with surface mounted motors, so much so that a opted for larger solenoid types, mounted under my board, which is out of the question with your layout. Another problem I had though was voltage and I solved that by powering all my point motors from an old lap PSU, that provided 18v. I use the ESU decoders that do allow a separate PSU. Link to comment Share on other sites More sharing options...
