garrettendi Posted September 21, 2016 Share Posted September 21, 2016 I have the R1173 Western Master, and the supplied Pannier Tank seems to have stalling issues. It stalls on two sections of the track about a fifth of the time, and over the insulated frog about half the time when the frog is on the left side of the train. Turning the train around, so the frog is on the right side of the train is even worse, almost always stalling on the frog.I'm pretty confident there is no issue with the track, as I have a 0-4-0 loco converted from DC to DCC, which despite the shorter wheel base, runs almost perfectly, making full loops consecutive times with no stalls.The issue with the Pannier (0-6-0) is worse at slower speeds too. I think the problem could be with the loco itself, that maybe I need the pickups repaired, or new pickups installed to increase the wheels that pick up the signal. Or maybe it just needs a clean.But to refer to the title... I have considered installing a DCC Concepts decoder with stay-alive capacitor. Is this even possible as the capacitor is 15 mm long, and real estate inside the Pannier's chassis is limited.What are my best options? I am hopeless at electrical work, so I'd need to go to my local hobby shop for the works. Link to comment Share on other sites More sharing options...
KNAP Posted September 21, 2016 Share Posted September 21, 2016 These will do the full works on a loco, worth asking what they would recommend for your loco.http://www.oliviastrains.com/trains/mt/sending-your-own-loco/ Link to comment Share on other sites More sharing options...
NormanQ4 Posted September 21, 2016 Share Posted September 21, 2016 I was also of the understanding that the stay alive unit supplied with the DCC Concepts decoder would do as you wish.However, it did not make any difference whatsoever to my loco.I phoned DCC Concepts to complain about this and was informed that this particular stay alive unit is only designed to smooth out the running of the loco not to improve running over points, dirty track etc. It does not have enough oomph.To buy these units separately works out around £4 to £5 each.To do what you want you would need to buy a capacitor like TCS Keep Alive, NCE No Halt or Soundtraxx Current Keeper which are vastly more expensive, around £27 each.DCC Concepts say they are developing a capacitor that will do the job but not yet on the market.Apparently there has been court action brought by TCS against DCC Concepts for using the term Stay Alive as people like you and I liken it to Keep Alive when it is not. Link to comment Share on other sites More sharing options...
96RAF Posted September 21, 2016 Share Posted September 21, 2016 Take a look at the service sheet to see if the pickups are on all wheels as it may be it is lifting a wheel and losing contact. I had a Baccy Jinty that had moulded springs under the chassis which lifted the wheels over a point, so I filed them down for clearance. Link to comment Share on other sites More sharing options...
garrettendi Posted September 21, 2016 Author Share Posted September 21, 2016 I think the pickups are the problem yes. I'll take a look when I can. As for the "stay alive" further Googling backs up NormanQ4's experience, so it looks like I better go the cheaper route of fixing the pickups for now. Is it easy/cheap to add pickups to any wheels that don't have them? It's interesting if the frog IS lifting a wheel because my 0-4-0 runs pretty much perfect over it. Link to comment Share on other sites More sharing options...
garrettendi Posted September 21, 2016 Author Share Posted September 21, 2016 Stupid question here, but are there any changes to CV values that would help? Link to comment Share on other sites More sharing options...
Chrissaf Posted September 21, 2016 Share Posted September 21, 2016 You can make your own 'Stay Alive' for pence compared to commercially purchased items. This previous post gives some tips on how to construct one..https://www.hornby.com/uk-en/forum/post/view/topic_id/13404/?p=2.I post this for the benefit of other forum readers, as I note the OP's statement at being hopeless at electrical work. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted September 22, 2016 Share Posted September 22, 2016 No. If there are no volts, it won't go! :-) Link to comment Share on other sites More sharing options...
RDS Posted September 23, 2016 Share Posted September 23, 2016 I was also of the understanding that the stay alive unit supplied with the DCC Concepts decoder would do as you wish.However, it did not make any difference whatsoever to my loco ... I had exactly the same experience with this 'stay alive'. Link to comment Share on other sites More sharing options...
BagEndJct Posted May 29, 2017 Share Posted May 29, 2017 I had an ESU "stay alive" fitted to my Hornby 0-6-0 tank by Olivia's Trains and am very pleased with the result. It never stalls over points or the odd couple of places where my other 0-6-0s struggle (I'm thinking of having another given this treatment despite the cost as it makes such a difference). They fitted a 'Loksound 4 Decoder' as part of the process and the only problem I have now is when the loco is brought to a halt, it stops then briefly lunges forward again. Any thoughts on this please? Anything I can try changing in the decoder settings? Thanks Link to comment Share on other sites More sharing options...
Fishmanoz Posted May 29, 2017 Share Posted May 29, 2017 First thing I'd be doing would be disconnecting the stay alive to see if this changes the behaviour. There is also a quite complex relationship between sound and movement in a sound decoder in order to synchronise the two. I think I'd start by asking Olivia's to see if they have any thoughts given they set it up for you in the first place. Link to comment Share on other sites More sharing options...
BagEndJct Posted May 30, 2017 Share Posted May 30, 2017 Thanks. Although Railmaster reports the decoder as "Lock Sound 4" I don't have sound fitted. I think they used it to work with the stay alive device. I did ask Olivia's and they just suggested resetting the decoder, but am loath to do that as I think they had tested and set up the loco and settings are not the default ones. I don't know. I suppose I could note all the settings, reset it and, if it's a disaster, rewrite the original values. Me and wiring inside a loco do not mix so no way am I going in and disconnecting the stay alive. Sorry!! Link to comment Share on other sites More sharing options...
Fishmanoz Posted May 30, 2017 Share Posted May 30, 2017 Who do you mean by"they" used it working with the decoder. And sounds a bit strange it reporting itself to be a Loksound if it's not. So definitely do a reset, then see how it goes and what it now reports itself to be. Yes, take a note of the settings but I wouldn't be too worried about losing them as they clearly aren't working well. Link to comment Share on other sites More sharing options...
BagEndJct Posted June 1, 2017 Share Posted June 1, 2017 I did get on to ESU and it was suggested that I change CV52 to 5. Beyond me why but I tried it and, though I have not been able to test it extensively, it has not lurched forward since. Thanks as ever for the support on here! Link to comment Share on other sites More sharing options...
