Ruffnut Thorston Posted September 30, 2016 Share Posted September 30, 2016 Hi all. Does anyone supply DCC sockets, preferbly with blanking plugs included, preferbly with wire tails attached, to fit to older Non-DCC-Ready locos? It would be better than just hard wiring a decoder methinks, as the option to change out the chip and alo run on pure DC would be available, as for a DCC fitted loco... Thanks... Link to comment Share on other sites More sharing options...
Chrissaf Posted September 30, 2016 Share Posted September 30, 2016 Like these for example.....plus blanking plugs are stocked by Hattons (plugs also on ebay if you search. Both items may even be available from same ebay seller to save P&P).. Link to comment Share on other sites More sharing options...
Ruffnut Thorston Posted September 30, 2016 Author Share Posted September 30, 2016 Thanks Chris.... That looks likely! Your signature is correct.... 😉 Chris........ Making the wood in the trees visible. I am just getting started with DCC.... So far 1 loco with hard-wired chip fitted, and a Fleischmann Loc-Boss controller! Link to comment Share on other sites More sharing options...
96RAF Posted October 3, 2016 Share Posted October 3, 2016 I have used the normal Hornby loco 8 pin sockets (sourced from Peters Spares) as well as these NEM 652 sockets pictured which I got from Ali-Express for about 30p each (for 10 or more), post free.You can solder direct to the latter's pins as per the ones Chris linked to or you can mount them on a bit of vero-board with a couple of mounting screw holes drilled in to make installing them in a loco easier. I just sticky pad these in. /media/tinymce_upload/87ef1e26105a71e9b95caa217ab8323d.JPG Link to comment Share on other sites More sharing options...
Ruffnut Thorston Posted October 3, 2016 Author Share Posted October 3, 2016 Hi RAF96 Thanks for the information. Seems like a good idea for the future, when I have a map of which pin needs which colour wire for NMRA installations. In time I will be installing quite a few decoder sockets / decoders! 😉 Link to comment Share on other sites More sharing options...
Chrissaf Posted October 3, 2016 Share Posted October 3, 2016 When this page opens, scroll down a bit further and there are diagrams showing the pin / wire colour mappings. Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 3, 2016 Share Posted October 3, 2016 Read the lot while you are there Sarah, great source of DCC info, as I'm sure Flashbang will agree. Link to comment Share on other sites More sharing options...
Ruffnut Thorston Posted October 4, 2016 Author Share Posted October 4, 2016 Much thanks! Now that is a mine of information, especially the "Stall Current" measuring set up! I will be fitting some DCC gear to X.04 powered locos, so this will help! More reading to do! I like reading....Research is Fun! ;) Link to comment Share on other sites More sharing options...
96RAF Posted October 4, 2016 Share Posted October 4, 2016 @sarahwhen doing stall checks make sure your meter can take the current as many only run to 200mA.if so then you can still do it by mesuring voltage using a shunt Then pplying ohms law to find the current.someone will come up with a diagram shortly I'm sure.lidl recently did a cheap 10A capable meter. Link to comment Share on other sites More sharing options...
Ruffnut Thorston Posted October 4, 2016 Author Share Posted October 4, 2016 Hi. I have a 10A capable multimeter....I think it came from Aldi years ago now! 😉 My first wired sockets arrived this afternoon.... Blanking plugs on order (in the post). Now I'll need some decoders! 😆 Link to comment Share on other sites More sharing options...
