MikeC176 Posted October 2, 2016 Share Posted October 2, 2016 Good evening all,I have recently updated to the latest railmaster and wondered if anyone can help me out with some bugs.I am running a laptop with Windows 7 x64 Service Pack 1.Since upgrading to the latest Railmaster, 2 main issues I have are as follows - 1) When a loco / wagon de-rails and shorts the track, the software no longer prompts to state that a short has been detected and click ok once its been cleared. Instead I have to restart the software and the eLink.2) When using the mouse to increase or decrease speed on a loco from the min Rail Master screen, the software seems to think the mouse is still increasing the locos speed when its not. This results in a loco fyling around the track, and the resolution is to restart the Rail Master software.Any help will be much apprciated. Link to comment Share on other sites More sharing options...
Chrissaf Posted October 2, 2016 Share Posted October 2, 2016 With regard to issue 1).Your railmaster.ini file needs these two lines in it.Alternative comms=1Check controller=1.To check and edit your railmaster.ini file, open the 'Help' window (RM top navigation bar). Click the 'COG' icon on the 'About' tab and follow on screen prompts. After editing the file and saving it, close and reopen RM..TIP: even if the two lines above are present as written. Delete them and re-type them again at the end of the .INI file as the last two entries. Doing that sometimes helps..Can't help you with issue 2) Link to comment Share on other sites More sharing options...
96RAF Posted October 3, 2016 Share Posted October 3, 2016 Pages 50/51 of the RM maual talks to mouse control. Also Page 26 talks to how the throttle slider behaves when the mouse is clicked/unclicked depending upon certain other settings.It may be that your RM setup is not correct or it maybe your basic mouse config (in Windows) is set such that the wheel is set to scroll more than 1 line with each click, which may affect how RM sees the commands - could be wrong - often am, but worth a look.If not then report the snag to HRMS. Link to comment Share on other sites More sharing options...
Mantagt Posted October 3, 2016 Share Posted October 3, 2016 I have been experiencing the the same problem with the mouse, the pointer seems to stick to the slider and i have to click it to release it. This can happen on other icons too and changing the mouse has no effect.1.64 does seem to have a lot of annoying bugs including slower start up and slow communication with the elite, it also looses contacted with the elite if left for a few minutes and has to be restarted. Most bugs seem to have appeared with rev 1 and I am considering reverting to 1.63 as a had no problems with that and was a lot quicker on my Win 8 laptop Link to comment Share on other sites More sharing options...
96RAF Posted October 3, 2016 Share Posted October 3, 2016 Yes I have had the expanded throttles sticking to the mouse and being dragged around the screen, not just with this revision. Link to comment Share on other sites More sharing options...
Chrissaf Posted October 3, 2016 Share Posted October 3, 2016 There have been two undocumented revisions to revision 1 since the 5th Sept download update date shown on the RM forum page. The file stats still report it as 1.64.1 though. Depending upon when you ran the installer, you may have an earlier version..The slower start up was introduced on purpose (it is not a bug) to fix a different bug in the initial 1.64.1 release on 28th Aug 16 where some users (me included) lost the points setting on 'start up' feature. This was fixed in the 29th Aug release when the slower start up was introduced. There have been two further unannounced (silent) revisions to the installer file since then. One on the 12th Sept and the last one on the 17th Sept. I suggest downloading and running the installer from the download link at the top of the RM forum again to ensure you have the very latest version. .The mouse and throttles seem to have been a long standing issue though. It doesn't affect me as I use a 'touch screen' for RM. I seem to vaguely recall someone posting a 'work around' so worth searching the forum for it. Link to comment Share on other sites More sharing options...
96RAF Posted October 3, 2016 Share Posted October 3, 2016 I do wish RM would adopt plain to see industry standard software configuration control, then we would all know exactly where we stand, rather than relying on the likes of Chris to try to keep tabs on what on earth revision state we are all operating. For goodness sake its not rocket science (which in itself isn't so difficult), so why they can't run with v1.64.1.n I do not know, then in the bottom RH corner hover over it could say Rev 1.0, 1.1, 1.2, etc. How can they even know what partial hidden revision state we are each at when we are reporting a fault in, unless there is a covert code in there somewhere. Link to comment Share on other sites More sharing options...
Chrissaf Posted October 3, 2016 Share Posted October 3, 2016 I suspect that some, not all, of these silent revisions relate to the loco database background updates. In other words, when a loco database background update is released the modified database is incorporated into the downloadable installer. This affects the byte count of the installer and that is what I see on my daily checks..With regard to the background loco database updates. These normally happen silently without much notification. I did recently (maybe just due to a temporary glitch in my Internet connection) catch a glimpse of a red text message appearing in the RM notification bar just to the right of the 'program' running box. The red text flashed up very briefly, so I didn't have time to fully read and memorise, but I did see the words 'Downloading' & 'Update' in the text. This occurred during the RM starting up & loading procedure, just prior to the points going through their start up firing routine. Link to comment Share on other sites More sharing options...
MikeC176 Posted October 3, 2016 Author Share Posted October 3, 2016 Thanks for all your suggestions guys, I will look into them tonight and let you know how I get on. Personally I think there are a lot of these bugs due to Rail Master trying to cover too many operating systems. I know a year or so ago it included the ability to run on Windows 2000 - my view is if Microsoft have not supported a product for years then why should Rail Master? Link to comment Share on other sites More sharing options...
Chrissaf Posted October 3, 2016 Share Posted October 3, 2016 I have a different view. RM has in my view been tinkered with over the years to make it run on later Windows Operating Systems. It's core code was and still is, again in my view, written for XP. Thus RM is long overdue for a complete ground up back to basics rewrite for the currently available 'Operating Systems'. Then it should auto detect what controller is attached and any comm ports that change and not need to have .INI files tinkered with. In other words, much more user friendly from a setting up perspective and less prone to need manual configuration edits to overcome hardware communication problems. Link to comment Share on other sites More sharing options...
Yelrow Posted October 3, 2016 Share Posted October 3, 2016 Quite right Chris, several XP users, and Vista users, run it without fault, as do i 99 % on windows 7. The difference between Mike and i being that i have NOT upgraded to 1.64, any more than i have with Elite/ select. My view was, as it ran fine, why tinker. There is quite enough to do on the layout, without continually making problems for yourself by grabbing all these relatively untested up dates., and then finding new snags. john Link to comment Share on other sites More sharing options...
TonyO Posted October 3, 2016 Share Posted October 3, 2016 I also agree with Chris but I suspect the problem is that Hornby cannot financially justify a rewrite. Link to comment Share on other sites More sharing options...
Gitter Posted October 3, 2016 Share Posted October 3, 2016 Hi gents, as some-one who likes to come on to the forum 3 or 4 tmes a day, I have noticed ( no doubt, so have others) long periods where there is a distinct lack of posts on Rm category. Am I wrong in my thinking that the reason for this is Hornby are now getting a grip on all the snagging , that in hindsight was always going to rear it's ugly head. ( just glad I wasn't having to foot the bill ). No doubt a lot of credit for this goes to Hornby and their associated teams, but a great deal of the imput came from forum member, past and present. Great stuff. But keep putting your posts in, as I am getting withdrawal symptons when there is nothing to read, regards, Link to comment Share on other sites More sharing options...
MikeC176 Posted October 3, 2016 Author Share Posted October 3, 2016 I think thats a very good point Chris.... makes me think perhaps finding an old XP laptop would be the way forwards...... Link to comment Share on other sites More sharing options...
MikeC176 Posted October 3, 2016 Author Share Posted October 3, 2016 ... although not rewriting the code may give the competition the upper hand? Link to comment Share on other sites More sharing options...
MikeC176 Posted October 3, 2016 Author Share Posted October 3, 2016 I have edited the .ini file and that part works perfectly - thank you so much Chris.Now onto the mouse issue... ill keep you posted on how I get on.... Link to comment Share on other sites More sharing options...
Yelrow Posted October 3, 2016 Share Posted October 3, 2016 Gitter, the lack of posts is down to the problems mostly being the same. There are still little niggles that await sorting, and no i dont think there grip has improved. john Link to comment Share on other sites More sharing options...
MikeC176 Posted October 3, 2016 Author Share Posted October 3, 2016 Thank you RAF96 for pointing me to the 'mouse control' section of the manual - I definitely think this is whats causing the issue and will look into it in more depth during the week. Link to comment Share on other sites More sharing options...
Gitter Posted October 3, 2016 Share Posted October 3, 2016 ah John , go back a couple of yrs to the forum , and the problems , as you say were of every type, you were quite a regular, who like myself, required some coaching to get satisfaction. I consider myself fortunate that I was running xp and i had an elite. Now I very rarely get any agro , apart from things that I could or should have done better. I am very satisfied with Rm and I am sure you yourself are not experiencing the hassle which perhaps was eating up time and enjoyment of our great hobby. All entitled to our opinions , but I think Rm is on the way up from a hard time. regards.P.S. when we get Loco Detection from Santa for Xmas we can all have champagne, and every thing in the garden will look great. You'll get the drink cheaper than we will. Link to comment Share on other sites More sharing options...
Yelrow Posted October 3, 2016 Share Posted October 3, 2016 Gitter, pity about your wishful thinking. Would have liked to open the champagne, but belive that particular boat has sunk. john Link to comment Share on other sites More sharing options...
RDS Posted October 3, 2016 Share Posted October 3, 2016 ... when we get Loco Detection from Santa for Xmas ... Is that a guess for LD sweep? Link to comment Share on other sites More sharing options...
Gitter Posted October 3, 2016 Share Posted October 3, 2016 Hi RDS, no, like everybody else I was miles out the last time. but suprises do happen now and then. Just trying to get the glass of water into 1/2 full mode I guess, but we live in hope. Link to comment Share on other sites More sharing options...
markp123 Posted October 4, 2016 Share Posted October 4, 2016 I have a different view. RM has in my view been tinkered with over the years to make it run on later Windows Operating Systems. It's core code was and still is, again in my view, written for XP. Your correct that's it's for "optimised" for XP as RM is written in the language Microsoft Visual Basic 6. Microsoft actually ended official support for VB6 back in April 8, 2008. Fortunately for the RM developers and Hornby, Microsoft have continued to support the VB6 runtime through to Windows 10. How much longer though I cannot say.As a developer by day we now use the modern equivalent Visual Studio .NET and C#. I still have one legacy application in VB 6 and although it "works" it's screaming to be brought up to date. But the company cannot afford to because VB 6 does not migrate well to newer languages without a lot of changes. Link to comment Share on other sites More sharing options...
Chrissaf Posted October 4, 2016 Share Posted October 4, 2016 I was fairly certain that RM was written in a near obsolete Visual Basic version, but didn't want to make such a statement in text in case I was wrong..Microsoft have continued to support the VB6 runtime through to Windows 10. How much longer though I cannot say..Maybe, MS would be doing RM users a favour if they did finally pull the plug. Then that would force HRMS's hand to do a full rewrite to create a more modern application. HRMS hinted that the next proper update to RM would be sometime nearer Christmas......I wonder if........but I doubt it. Link to comment Share on other sites More sharing options...
