Spireblade Posted October 5, 2016 Share Posted October 5, 2016 How do I get the list of locos on the right hand side of RM into number order? They are all mixed up and it's annoying the hell out of me that loco number 16 is at the top. Link to comment Share on other sites More sharing options...
Chrissaf Posted October 5, 2016 Share Posted October 5, 2016 Could you post a screen capture showing the loco list on the RHS, there may be something about how the locos are numbered or named that have a bearing on listed order. Something may be obvious, if we can see it. Link to comment Share on other sites More sharing options...
Chrissaf Posted October 5, 2016 Share Posted October 5, 2016 Just had a thought. Could they be listed in the order in which you added the loco to RailMaster..I have 7 locos for reasons I won't bore anybody with I have them numbered 0101, 0102, 0103.......0107.In my case they all show listed on the RHS in that same numerical order. However that also happens to be the same order that I installed them into RM. In my RM system, they are definitely not listed alphabetically based on loco name or R stock number. Only two of the five are Hornby anyway, so R number or name cannot be the basis of list order. Link to comment Share on other sites More sharing options...
Chrissaf Posted October 5, 2016 Share Posted October 5, 2016 Only "two of the five" should read "only two of the seven" the post EDIT button still missing, so couldn't amend the original text. Link to comment Share on other sites More sharing options...
RDS Posted October 5, 2016 Share Posted October 5, 2016 The order they are listed, is nothing to do with the order you entered them or how the Loco's are numbered.You decide the order from the 'Set up Locomotives' icon. (2nd one from the left at the top of the screen)Click on that icon and it lists out all your Loco's. Click on the Loco that you want to move and at the bottom of the window are up and down arrows, which when clicked will move the selected Loco in the direction you have chosen. Then click on the tick in the bottom right corner to save your newly sorted list. Link to comment Share on other sites More sharing options...
RDS Posted October 5, 2016 Share Posted October 5, 2016 (continued from my previous post above)..... After saving the new order, close the window down and the newly sorted Loco order wil appear on the right hand side. Link to comment Share on other sites More sharing options...
Chrissaf Posted October 5, 2016 Share Posted October 5, 2016 I've just come back into the forum to post the same answer as RDS. Fired up my RM laptop to see what could be done about setting order. Although in my case, they are all listed in the order I entered them. I found the two arrows (one up & one down) in the 'loco setting screen' and found I could use the arrows to reorder the list. Link to comment Share on other sites More sharing options...
Chrissaf Posted October 5, 2016 Share Posted October 5, 2016 See also bottom of page 46 and top of page 47 of the current RM manual, where the list re-ordering feature is described. Link to comment Share on other sites More sharing options...
Spireblade Posted October 6, 2016 Author Share Posted October 6, 2016 Yes., for reasons only I could think of, they are in order of how I entered them on RM. I looked in the drop down menu to try and re order them using the arrows but it didnt happen. It just highlighted the loco in blue and that was it. I'll try again later. Link to comment Share on other sites More sharing options...
Chrissaf Posted October 6, 2016 Share Posted October 6, 2016 Before using the up and down arrows. Select the loco in the list you want to move../media/tinymce_upload/0daf1fcea1edabc59f6a81fc0a64a278.jpg. Link to comment Share on other sites More sharing options...
Chrissaf Posted October 6, 2016 Share Posted October 6, 2016 Forgot to add in the absence of a working EDIT button..To 'Select' the loco (step 1) use the mouse pointer to click on the loco entry. I found clicking the loco name worked best (where my white arrow is pointing at). Link to comment Share on other sites More sharing options...
Spireblade Posted October 6, 2016 Author Share Posted October 6, 2016 And there we have it. I hadn't actually highlighted the loco, I was just trying to shift it up the list... Anyway, all is done. Thanks Link to comment Share on other sites More sharing options...
