whiteshield Posted October 22, 2016 Share Posted October 22, 2016 Cannot get railmaster to write cv's to loco's, have tried half a dozen all brand new all Hornby. Have tried the following:New leadDifferent portMain track and programming trackUpating the softwareHave checked all settings and they seem to be right. According to Hornby the E-link works as they recently returned it, for the second time, saying they had repaired it. The first time they said it was working properly, strange that.Any help would be appreciated.John Link to comment Share on other sites More sharing options...
Chrissaf Posted October 22, 2016 Share Posted October 22, 2016 Have you tried it with the eLink programming port ONLY, connected to the programming track - i.e with the main track output disconnected from the eLink altogether..Does your railmaster.ini file contain the following lines:.Alternative comms=1Check controller=1.To check and edit if necessary, click the COG icon found in the 'Help' 'About' window and follow on screen prompts. Link to comment Share on other sites More sharing options...
whiteshield Posted October 22, 2016 Author Share Posted October 22, 2016 Hi Chrissaf,Yes done all of those. Link to comment Share on other sites More sharing options...
Yelrow Posted October 22, 2016 Share Posted October 22, 2016 Whiteshield, hi, before we get too complicated, have you managed to read any cvs yet, bearing in mind all your locos, are set at 0003 from factory. I had exactly same prob when i started, and was doing it wrong. Can you say exactly what you are doing, step by step, and it may be, we can put you right. Also, the the history of topics, is a full set of idiots guide how to do this, as it was posted for me. john Link to comment Share on other sites More sharing options...
whiteshield Posted October 22, 2016 Author Share Posted October 22, 2016 Hi Yelrow,No. None at all.Been following the instructions as supplied by Hornby. Link to comment Share on other sites More sharing options...
Yelrow Posted October 22, 2016 Share Posted October 22, 2016 Thats where i think you are going wrong, have a look through the old posts, there is a proceedure that needs following to the letter. I will try to find the old post. there wont be an elink fault, they are very rare. its just the way its done. No doubt some one with an elink will help you. john Link to comment Share on other sites More sharing options...
whiteshield Posted October 22, 2016 Author Share Posted October 22, 2016 Thank you. Link to comment Share on other sites More sharing options...
Yelrow Posted October 22, 2016 Share Posted October 22, 2016 ok here goes, Place loco on prog track, Click set up locos Press button which looks like an exclamation mark, with a circle round it Enter 1-16 in CV range. RM will then read CV of loco. OK so far. When it has finished reading Change cv1 to new number, eg 008 Press oblong box, with another oblong inside it for it to write to new number. YES,,,,, Select DCC ID to new loco Set cruising speed , shunting speed Name loco Set any functions. Write all this down clearly, as you go, and keep it close by. Let me know how you get on. john Link to comment Share on other sites More sharing options...
whiteshield Posted October 22, 2016 Author Share Posted October 22, 2016 Thanks for that John. I'll give it a try, probably won't be for a few days but I will let youn know if it works. John Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 22, 2016 Share Posted October 22, 2016 Or you could go to the second top locked thread in the forum title Setting Up and Getting Started where I think the 3rd post is originally from HRMS giving the full procedure for writing and saving both short and long loco IDs. This is in fact the post I think John was struggling to find for you. Link to comment Share on other sites More sharing options...
96RAF Posted October 23, 2016 Share Posted October 23, 2016 I have also found that just overtyping in a value box didn't take, I had to backspace the existing numbers out before typing in the new ones, then press the pencil icon (on my colour scheme that is) to write the new value. Link to comment Share on other sites More sharing options...
whiteshield Posted November 4, 2016 Author Share Posted November 4, 2016 Have tried the suggestions, all I get is an error reading message. Cannot increase the read time as as soon as I press the green tick it go's back to four seconds. Have tried on half a dozen loco's all brand new and all Hornby but none work. Elink has been back twice, first time told there was no fault found second time that repaired it. Very strange that. Am fed up with it as I have spent many hours trying to get it to work but nothing does.John Link to comment Share on other sites More sharing options...
Yelrow Posted November 4, 2016 Share Posted November 4, 2016 What i would suggest is you do what i did firdt time, and go through it on the phone with Mark Lodge at Hornby. Ask him to ring you back, when he has 15 mins spare, and he will actually talk you through it, while on the phone. I am sure, its something that you are not doing or doing in the wrong order. If he cant get it to work. nobody can, and he is the guy who will replace, if faulty. john Link to comment Share on other sites More sharing options...
St1ngr4y Posted November 4, 2016 Share Posted November 4, 2016 Have you tested the programming track with a multimeter to ensure that there is power getting through when you are trying to access the CVs?Ray Link to comment Share on other sites More sharing options...
Chrissaf Posted November 4, 2016 Share Posted November 4, 2016 Whiteshield, can I ask how you physically have your programming track piece connected to the eLink A&B Programming output..Do you use a power clip to connect to the Prog Track, if so is it a proper Digital clip and not an Analogue clip - see further below for info on part numbers.Alternatively, are the wires soldered directly to the programming track piece (in my opinion - recommended).Are the wires between the prog track and the eLink direct point to point and relatively short i.e don't go through any additional switches or connector arrangements.Have the rails of the Prog Track been scrubbed with a track cleaner rubber to ensure that they're spotlessly clean..Digital power clip R8241Digital power track R8242.Analogue power clip R602Analogue power track R8206.The Analogue power versions can be converted to Digital versions by removing the 'Suppression Capacitor' under the plastic connector cover. If present, just snip through the two leads and discard in the bin..Here are three YouTube videos in a 3 part series. They're fairly short but I haven't sat down and watched them all the way through. However, they are for RM and eLink and cover trying to read & write CVs.. the decoder is faulty and the process fails. a new decoder is fitted and the configuration is completed OK the newly configured loco is tested..I have included them, so that you can compare the reading / writing process to how you are trying to do it, to see if your problem is operator error..In addition to above, here is another loco programming video by a different YouTube presenter showing the CV process from a different perspective.. Link to comment Share on other sites More sharing options...
whiteshield Posted November 4, 2016 Author Share Posted November 4, 2016 Thank you for your replies.Yelrow I spoke to Mark as you suggested and have got loco's running round the main track. Not sure why as I had already tried what we did. Yes Ray I tested for power and that seems ok.Chris the test track wiring is soldered directly to the track, but we could not programme any loco's. I will replace the track and cable over the next few day's I hope.Will keep you posted.Thanlks John Link to comment Share on other sites More sharing options...
Yelrow Posted November 5, 2016 Share Posted November 5, 2016 Whiteshield, thanks for your feedback, i thought mark would be able to help. He has this fixed step by step set of instructions, that appear to work, despite as you say, us trying the same thing, but, (not necesarily in the same order). john Link to comment Share on other sites More sharing options...
whiteshield Posted November 7, 2016 Author Share Posted November 7, 2016 Fully agree with you Yelrow.Completely redid programming track and it now works fine. Track I origanilly used was old track replaced with new and new wiring incase there was a break in it.Decided to renew all wiring under the layout as it was running a bit iffy, going to solder conections instead of using jointing blocks. Also renewing some of the track and will only use new infuture as I think this will help.Thanks again for all your help.John Link to comment Share on other sites More sharing options...
Chrissaf Posted November 10, 2016 Share Posted November 10, 2016 Whitesheild's fix for this issue shows how important it is to use good clean track and well terminated wiring for programming. The programming output in DCC uses very low power. It is critical to have a 100% electrically clean signal path between the controller and the decoder. So many people seem to think, oh its only used for programming. I'll just use whatevers lying around in my box of bits. Link to comment Share on other sites More sharing options...
