suriraj Posted November 7, 2016 Share Posted November 7, 2016 I have Hornby tracks and points controlled by Cobalt Digital iP motors. Recently bought Mallard loco with TTS . It keeps derailing at certain points Other locos pass with out any problem.I have similar problem with Gadwall which looks similar to Mallard.The points are level ,checked with spirit levelAny suggestions will be appreciatedThanksSuriraj Link to comment Share on other sites More sharing options...
52train Posted November 7, 2016 Share Posted November 7, 2016 Have you check the back to back messurement of the wheels, if other loco's run with no probems that might be it. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted November 7, 2016 Share Posted November 7, 2016 What radius are the points? Modern steam outline OO loco's don't like turns tighter than r3, or the bogies catch on the cylinders, steps, etc.Which loco wheels are derailing? Link to comment Share on other sites More sharing options...
suriraj Posted November 7, 2016 Author Share Posted November 7, 2016 I have Hornby track plan 10/13 in the 12th edition. It passes thru some points but over some points the small front wheels derail. Other older locos like Thruster shunter Royal Scot have no problem Link to comment Share on other sites More sharing options...
Fishmanoz Posted November 7, 2016 Share Posted November 7, 2016 It is an unfortunate fact that some Hornby track plans have less than ideal combinations of track included in them. This includes the use of smaller radius curves versus larger radius and standard versus express points. Larger locos can have problems on both of these, especially where one piece is mounted directly against the other with no straight sections in between. In this regard, layout 10/13 has any number of places where points are adjacent to second radius curves and I'm betting these will be the ones where you are having problems. In these cases, your only solution will be to ensure that the points are laid dead flat and have all parts of the points level without plastic frogscprotruding upwards, the back to back measurements on your front bogies are spot on, that they have good loading onto the track via washers or springs and that they can achieve the extremes of turning needed without fouling steps, pistons etc. Link to comment Share on other sites More sharing options...
suriraj Posted November 8, 2016 Author Share Posted November 8, 2016 Thanks Fishmanoz Link to comment Share on other sites More sharing options...
Jezza62 Posted November 10, 2016 Share Posted November 10, 2016 I've found correcting the back-to-back wheel measurements have cured my issues with derailments on points Link to comment Share on other sites More sharing options...
