The Captain90 Posted November 8, 2016 Share Posted November 8, 2016 When I start Railmaster and make the first "click" on the layout mimic, the plan flashes for about 10 seconds before settling down. After this all is OK.Any thoughts why this is so? Link to comment Share on other sites More sharing options...
St1ngr4y Posted November 8, 2016 Share Posted November 8, 2016 I may be wrong, but I think it does this if you have asked for points and signals NOT to be set at startup.Ray Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted November 8, 2016 Share Posted November 8, 2016 Can you ensure you are using the latest version of the program by downloading and installing from www.rail-master.com/rm_setup.exe (there is no need to uninstall or deactivate and your user data will be fine). If the flashing persists (more than a couple of times) let us know by emailing support@rail-master.com. Link to comment Share on other sites More sharing options...
The Captain90 Posted November 8, 2016 Author Share Posted November 8, 2016 You are right again Ray. The plan only flashes if I select do not set points at startup. Link to comment Share on other sites More sharing options...
