SteveWillis Posted December 3, 2011 Share Posted December 3, 2011 Is anyone having trouble reading the address of the new Loksound v4 decoder on an Elite? When reading the address I get random addresses for both Clun Castle and the Class 08 shunter. I can read all other loco addresses, including Loksound v3.5 decoders.I have the latest Elite firmware and have tried a unit reset without any success. Everything else works, including writing a new address, but I would be interested if anyone else has had the same problem reading the address and what, if anything, can be done about it. Link to comment Share on other sites More sharing options...
Flashbang Posted December 3, 2011 Share Posted December 3, 2011 HiBefore going much further, I would thoroughly clean the rail tops of the programming track and also clean the wheel treads of the loco. Then retry. Sometimes lightly holding down the loco onto the programming tracks rails will allow read or writing to happen. Of course some decoders cannot be read back (Not the LokSound) and some need several goes at reading a CV. Most of the problems are due to dirty rails or wheels, as the programming side of the console uses a much lower current flow to the programming track rails to prevent a decoder having full rail power applied to should it be faulty or wired incorrectly. Link to comment Share on other sites More sharing options...
stevecamden Posted December 3, 2011 Share Posted December 3, 2011 Just to add, that I had this issue with a loco from 'another place' using loksound V4 and re-setting the Elite solved it. It works fine now. Link to comment Share on other sites More sharing options...
