52train Posted November 19, 2016 Share Posted November 19, 2016 Right here goes layout down points down and coded, now I want to code train tech home signal to point so that when I change the point the signal changes.If I click on the signal the point changes but if I click on the point the point changes but not the signal. I am using elite with pro pack and a laptop.Ive watched Brian Hughs video's but Im missing somthing can anyone help.Many thanks Link to comment Share on other sites More sharing options...
RB51 Posted November 19, 2016 Share Posted November 19, 2016 Have you set the signal up to react to a point change in the "other signal / accessories" window in the point settings? R- Link to comment Share on other sites More sharing options...
52train Posted November 19, 2016 Author Share Posted November 19, 2016 AS far as I know I have done things right but I will try again. Link to comment Share on other sites More sharing options...
RB51 Posted November 19, 2016 Share Posted November 19, 2016 You should set Train Tech signals to react to the same DCC ID as the point you are operating. What is confusing is when you say "if I click the signal the point changes" - I dont think there is (or needs to be) any relationship between any signal icon on your layout plan and the Train Tech signal. R- Link to comment Share on other sites More sharing options...
RDS Posted November 19, 2016 Share Posted November 19, 2016 It seems to me that you have set the point up to respond to the signal, rather than the other way round. Link to comment Share on other sites More sharing options...
