Jayboy Posted November 29, 2016 Share Posted November 29, 2016 Hi all.New to this.have 2 digital lane changers.Both worked perfectly , however , one of them isn't working properly.The changer moves but not enough for the cars to change lanesI have moved the cars over the sensor slowly and the changers just ' blip' a small amount , like I say , not enough to actually make the cars change lanes.Cheers.Jason. Link to comment Share on other sites More sharing options...
Blagard Posted November 29, 2016 Share Posted November 29, 2016 Perhaps the first thing is to check the lane changer is getting full power, so swap it with the other one you have and see if the problem persists. If it is still under warranty you should get it exchanged. If it isn't then it may be time to tinker! Certainly you should first of all check for any signs of something obstructing the changer but assuming you have already done that and if it is out of warranty then you would be best to open it up for investigation. There are some videos on Youtube that may help. Edit:If you scroll roght down on the website linked below they have a section on the lane changerhttp://www.jadlamracingmodels.com/scalextric-faqs Link to comment Share on other sites More sharing options...
Jayboy Posted November 30, 2016 Author Share Posted November 30, 2016 Thank you for the heads up.I have something to go on now. Link to comment Share on other sites More sharing options...
Jayboy Posted December 2, 2016 Author Share Posted December 2, 2016 Blagard.Thanks for the help.All sorted. Link to comment Share on other sites More sharing options...
