GURU FROM INDIA Posted December 13, 2016 Share Posted December 13, 2016 Hello friends,I have 2 TTS Sound locos- Gadwal and Virgin(set) which work ONLY at LA- 3. I have 2 more sound locos who are very cooperative. I am trying to configure them on Select controller.Reply will be appreciated..ThanksG Link to comment Share on other sites More sharing options...
choralc Posted December 13, 2016 Share Posted December 13, 2016 1. With the Select controller make sure there is no other DCC decoder (loco or accessory) connected to your track. If you have a spare piece of track not connected to your layout you could connect to that using the power clip that came with your controller. 2. Place one loco on the track. Press and hold the 'SELECT' button for two seconds. The LCD should display 'LA' 3. Press keypad for the number you want the loco id. to be changed to. The LCD display should flash that number (in the Select manual they have the example of 1). 4. Press the 'SELECT' button again to programme the loco decoder with the number you chose in '3' above. The red led will flash up to seven times. If the red led flashes eight times start again. 5. The loco should now have the address you chose in '3' above. 6. Put this loco to one side off the track and place the next DCC decoder equipped loco on the track as in '1' above and repeat steps '2-4' using a different id. number. For loco addresses and the Select you can only choose from 1-59. It is possible that a loco that did not come with the Select in a Digital Train Set may only be DCC Ready (has a socket that will accept a locomotive decoder) and does not have a loco decoder fitted. Link to comment Share on other sites More sharing options...
walkingthedog Posted December 13, 2016 Share Posted December 13, 2016 The two TTS locos that don't work can't be DCC ready as they wouldn't be TTS choralc. Link to comment Share on other sites More sharing options...
Rog RJ Posted December 13, 2016 Share Posted December 13, 2016 With strange problems like this it is always worth resetting the Select controller. Resetting can often help with the Elite too when odd things happen. Link to comment Share on other sites More sharing options...
Howbi Posted December 13, 2016 Share Posted December 13, 2016 @Guru.........just in case you tried a higher number, the Select can only address up to 59.........HB Link to comment Share on other sites More sharing options...
RDS Posted December 13, 2016 Share Posted December 13, 2016 @guru from IndiaWelcome to the Forum and that is a very good point that 2 of our members have made above, advising that the Select will only allow numbers 1 - 59. What id number(s) were you trying to use? Link to comment Share on other sites More sharing options...
choralc Posted December 13, 2016 Share Posted December 13, 2016 WTD two other locos were described as sound locos but because I didn't read with understanding I did not know if they were new. I had the experience of buying a second hand XS model which had the sound decoder and speaker stripped out so was just speculating. Now of course I reread the OP and see that they are 'cooperative'. And in case he missed HM's post about 1-59 only use two-digit addressing. 😆 Link to comment Share on other sites More sharing options...
GURU FROM INDIA Posted December 14, 2016 Author Share Posted December 14, 2016 Thanks friends for replies.@choralc- Thanks for the detailed response. I have attempted to reset as @rog recommends but has not worked. What I have not tried is to program on a separate track. I shall try today and keep all posted.Thanks muchGuru Link to comment Share on other sites More sharing options...
RDS Posted December 14, 2016 Share Posted December 14, 2016 @guru from India.It is essential to program on a separate track, unless the Loco being programmed is the only Loco on the track and you do not have any DCC accessories, such as points, that have their own addresses.In order to be certain you are only programming the Loco you want to program, a short length of separate track is highly recommended. Which id numbers are you trying to program? Link to comment Share on other sites More sharing options...
ff2nd Posted December 22, 2016 Share Posted December 22, 2016 What Firmware are you running on the Select, i.e. what is the FIRST number it displays when it starts up? The Select needs to be up to date to work with TTS properly, so it would show 15, then 30, then 03. Link to comment Share on other sites More sharing options...
