Monty1970 Posted December 13, 2016 Share Posted December 13, 2016 Hi all,Having just got back into modelling, i was wondering is it really neccesarry to put a layer of primer on the model before painting. If so why and what would happen if i didn't put primer on before painting ? Many thanksIan Link to comment Share on other sites More sharing options...
Ratch Posted December 13, 2016 Share Posted December 13, 2016 No you don't NEED to, but sometimes it helps Link to comment Share on other sites More sharing options...
DavidJC Posted December 13, 2016 Share Posted December 13, 2016 I agree, you don't need to. In fact over the years I hardly ever have. However, there are some colours that would benefit from it, not least yellow (or even red) over white primer. Link to comment Share on other sites More sharing options...
Gareth McFadden Posted December 13, 2016 Share Posted December 13, 2016 I find priming sometimes helps give the Humbrol acrylics better adherance to the model. In my experience the Humbrol enamel matt range adheres better to the bare plastic than acrylic or even enamel gloss or enamel so I might use a Humbrol enamel as my primer if other more fragile or translucant paints are required for the build. Priming also levels out the surface texture and colour if filler has been used. It also helps to reveal surface flaws. As David says, it can help to give a good base for certain colours: white, red, yellow, orange and metallics benefit from a good base coat. Link to comment Share on other sites More sharing options...
John Symmons Posted December 14, 2016 Share Posted December 14, 2016 Hello Monty 1970If you're using acrylics especially the water based ones like Humbrol and Vallejo, I've found that adhesion can be a problem. Tamiya are not water based but solvent based and as such tend to adhere much better like the matt enamels. Also washing any mould releasing compound from the model helps, but to really illuminate any prolems priming is these days recommended especially if using acrylics and or the colours mentioned above.A lot of modellers use Tamiya matt acrylics; myself included; to prime the model using an airbrush.Remember we do this for fun John the Pom Link to comment Share on other sites More sharing options...
Monty1970 Posted December 14, 2016 Author Share Posted December 14, 2016 Cheers for all the feedback, much appreiciated 😀 Link to comment Share on other sites More sharing options...
Andrew Taylor1707819856 Posted December 16, 2016 Share Posted December 16, 2016 As far as humbrol enamels go, the flourescent orange usually benefits from a regular orange primer. Link to comment Share on other sites More sharing options...
Sailorman Posted December 16, 2016 Share Posted December 16, 2016 I believe it virtually always pay to prime. That way you can check whether there are any blemishes, gaps or any other areas that need to be touched up. You'd be surprised what a coat of primer will reveal. You can then do the necessary touch-ups and your final coat will be that much better. Link to comment Share on other sites More sharing options...
ntrocket88 Posted December 20, 2016 Share Posted December 20, 2016 Priming is also essential for resin and white-metal kits, regardless of the paint used. For the white-metal I have found it necessary to a use self-etching primer. Tamiya make a spray can of this, but it is very difficult to get in the US. Automotive self-etch primer seems to work too. Link to comment Share on other sites More sharing options...
Braille Dave Posted December 20, 2016 Share Posted December 20, 2016 I never used primer until recently. Now I tend to use Halfords grey primer for most colours, with white primer for yellow, red, orange and... white.A conversation (over a pint, of course) with a car restorer, has convinced me of the value of a good primer, not only to spot all the little defects that appear from nowhere, but also to get a good adhesion and depth of colour. Link to comment Share on other sites More sharing options...
