Spireblade Posted December 18, 2016 Share Posted December 18, 2016 I have a small issue regarding a converted Lima DMU. Although programmed through Railmaster and Elite, when using it in RM the top speed is just a crawl. When used using the Elita alone it behaves like all my other locos and has a high top speed. Is there a reason for this and can I sort it out so that through RM it runs normally?It says on the slider that it is running at 70mph, but its more like 10. Cheers and compliments of the season to you all. Link to comment Share on other sites More sharing options...
Chrissaf Posted December 18, 2016 Share Posted December 18, 2016 Spire, In RailMaster the default configuration is to use 'Scale Speeds' this is not so when directly using the Elite buttons and knobs. There is probably something in the RailMaster 'Scale Speed' settings for this particular loco that is affecting it. Review the RailMaster 1.64 manual pages 25, 35 & 36..Note: when you are using the Elite feedback into RM throttle feature you are still in effect using the Elite to control loco speed, not RM. Link to comment Share on other sites More sharing options...
Spireblade Posted December 18, 2016 Author Share Posted December 18, 2016 Ok thanks. I'll take a look at that. I was thinking that the Elite used the RM settings to control the locos. Link to comment Share on other sites More sharing options...
