Mimic Plan - Point Graphic
Hope I describe this so it can be understood. I have now installed and fitted point motors (& associated wiring) to 8 electrofrog points (16 to go). All are working fine except for a minor issue with the last one installed. When I click on the appropriate icon on the layout mimic plan the point changes fine but the blue line within the point graphic doesn't move - it stays in the one direction regarless of the point change.
I have deleted the point and the point change arrows from the plan and reinserted but to no avail.
Any thoughts as to whats happening.
Morning Captain. Usually this is because the point icons (red and green buttons) are not correctly aligned with the point they operate. They have to exactly sit over a crossover in the grid. Try removing them and putting them back but this time move the red button (with your mouse) to the centre of the point itself and then let go. You should find that it will correctly snap to the correct location and the green button will follow suit. R-
I have answered many Captain questions I have found him reliable in coming back to reply, but he does sometimes take a few days to do so.
Captain is in OZ (summer there at present) doubt that flu would be the reason. 😉 😆
I had this problem, spacing the points further apart as suggested solved it. if the point buttons are too close to another point they get confused, and you have to place the red button on the centre of the point when adding the buttons and the green should snap into place, if it doesn't then the points are still too close. You will need to adjust your track plan  to accomodate extra straights  so you can stagger the points out a bit.
Chaps (or Ladies). Yes I am still here but have been very busy over Christmas to try the suggested solutions. Will do so over the next few days and report back.
Just as an aside here in my part of OZ its been very extreme temperature wise - 42C+ (or 103F in the old money). This has caused some problems with the real railway in that tracks have warped or engines failed due to heat. My job is that of a Coach Driver so I have spent time in the last week driving coaches to replace trains. My last trip involved replacing the train from Newcastle to Moree (NSW) a distance of 500klm or 310miles). Might seem like a lot of work but I only carried 39 pax and did 4 stops.
