nomdeplume Posted January 1, 2017 Share Posted January 1, 2017 Hi, I bought my son a Thomas Hornby set for Christmas, along with a few track extension packs, and after a few days of fun, the engine now just seems to rev (whatever speed) and barely moves. He'll move a few centimetres with a push, and then just go back to revving. Any advice is gratefully recceived on how to get him moving again! Link to comment Share on other sites More sharing options...
RB51 Posted January 1, 2017 Share Posted January 1, 2017 Hi NDP - sounds as though the gears are not meshing. I'm not familiar with the loco but can you get the body shell off and see if the motor pinion is connecting with the gear on the axle. R- Link to comment Share on other sites More sharing options...
2e0dtoeric Posted January 1, 2017 Share Posted January 1, 2017 Are the wheels turning, but the train doesn't moveor is the motor whizzing, but the wheels don't turn.If the second - either the gear has come off the motor shaft, or the motor has been dislodged from it's seating.If the first, does the engine move on it's own?If it does, then one or more of the wheels on the trucks are jammed.Are you running Thomas on the carpet, or on a clean hard surface (under the track!)If it is nothing obvious (fluff) take the whole lot back to where you bought it, for repair or replacement.If on the carpet, you have probably got carpet fluff and muck in the mechanism. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted January 1, 2017 Share Posted January 1, 2017 Duplicate post! See my reply in the 'General' thread.As the set is new, do NOT take it to bits, that will void the guarantee. Take it back to the shop. Link to comment Share on other sites More sharing options...
RB51 Posted January 1, 2017 Share Posted January 1, 2017 All moved over here 2e0. R- Link to comment Share on other sites More sharing options...
nomdeplume Posted January 1, 2017 Author Share Posted January 1, 2017 Are the wheels turning, but the train doesn't moveor is the motor whizzing, but the wheels don't turn.If the second - either the gear has come off the motor shaft, or the motor has been dislodged from it's seating.If the first, does the engine move on it's own?If it does, then one or more of the wheels on the trucks are jammed.Are you running Thomas on the carpet, or on a clean hard surface (under the track!)If it is nothing obvious (fluff) take the whole lot back to where you bought it, for repair or replacement.If on the carpet, you have probably got carpet fluff and muck in the mechanism.Hi there, the the wheels aren't turning (only perhaps a rotation or two to start before just revving). It's running on track pinned to MDF so I'm pretty sure it's not fluff. I shall try looking at the motor shaft and report back. Many thanks Link to comment Share on other sites More sharing options...
trainlover23 Posted January 1, 2017 Share Posted January 1, 2017 This should be in the General Section not hidden away in ther Thomas Section. Anyway it sounds like a stripped gear and it will have to go back to Hornby for repair Link to comment Share on other sites More sharing options...
RB51 Posted January 1, 2017 Share Posted January 1, 2017 Why so TL23? At the moment it seems to be an issue relative to Thomas The Tank Engine. If it turns out to be a broader issue then we can move it later. R- Link to comment Share on other sites More sharing options...
trainlover23 Posted January 1, 2017 Share Posted January 1, 2017 Because more people look at the General Discussion Section Link to comment Share on other sites More sharing options...
96RAF Posted January 2, 2017 Share Posted January 2, 2017 Right at the top of the Thomas forum page:Thomas the Tank EngineThe iconic Thomas & Friends are enjoyed by both young children and avid collectors. Please keep all discussion of this fantastic range here. Says it all really... Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 2, 2017 Share Posted January 2, 2017 Good heavens, how do they expect to be misinterpreted when they make things as clear as that? Link to comment Share on other sites More sharing options...
olly Posted January 2, 2017 Share Posted January 2, 2017 Is the Thomas new ? .If it is it would be best to send it back to the retailer or Hornby for repair or replacement. It sounds like the gears not right and probably damaged Link to comment Share on other sites More sharing options...
