pidder Posted January 9, 2017 Share Posted January 9, 2017 I wonder if anyone has fitted a Hornby TTS Class 47 decoder in a Bachmann class 25 engine? This decoder seems to be readily available at the moment and I wonder whether the sounds would be reasonably suitable for the Class 25, and if so, how easy to install. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted January 9, 2017 Share Posted January 9, 2017 Sorry, can't help with the sounds comparison.This question would be better n the DCC threads, really. Link to comment Share on other sites More sharing options...
Howbi Posted January 9, 2017 Share Posted January 9, 2017 Hi pidder.........to compare engine sounds go to this site for live samples of all the diesels.........http://www.brdw.co.uk/sounds.htmlWith regard to cl25 & cl47, the difference is very noticeable because the cl25 is a Sulzer 6 cyl 1250hp motor whereas the cl47 is twice the size, a 12 cyl 2580 hp motor and just sounds a much heavier machine which, of course, it is..........but better to put the 47 decoder in the cl25 to make it sound beefier than tother way round......as for fitting the TTS decoder........should be a straightforward plug in to the socket if 8 pin but many Bachmanns are 21 pin so an adapter would be needed. The speaker would have to be fitted where space allows and possibly set in bluetac to stop it rattling around..........HB Link to comment Share on other sites More sharing options...
pidder Posted January 9, 2017 Author Share Posted January 9, 2017 howbiman Thanks, didn't realise the much different engine sizes, all diesels sound much alike to me. May give it a try, shall have to check for the speaker fitting... Link to comment Share on other sites More sharing options...
dynax Posted January 9, 2017 Share Posted January 9, 2017 you could use a class 20 tts decoder, Link to comment Share on other sites More sharing options...
2e0dtoeric Posted January 9, 2017 Share Posted January 9, 2017 all diesels sound much alike to me - - - Snap! :-) (Especially TTS) Link to comment Share on other sites More sharing options...
pidder Posted January 10, 2017 Author Share Posted January 10, 2017 Thanks everyone for your comments, (my post yesterday does not seem to have registered). As to Class 20 TTS, this does not seem yet to be available. Perhaps I'll wait and see what TTS units Hornby release. Link to comment Share on other sites More sharing options...
96RAF Posted January 10, 2017 Share Posted January 10, 2017 The (diesel) list I have is Class 31, 37, 47, 60 and 67.Steam list if of interest is A1, A3, A4 King and Castle classes. Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 10, 2017 Share Posted January 10, 2017 They are all in 2017 release list. Link to comment Share on other sites More sharing options...
pidder Posted January 11, 2017 Author Share Posted January 11, 2017 Nothing comparable to Classes 20 or 25 then? Link to comment Share on other sites More sharing options...
Sultan Posted January 12, 2017 Share Posted January 12, 2017 Class 20, 25 and 47 all sound markedly different and I would not recommend using the wrong chip in a loco as it will not be at all authentic. For a start the class 20 has an English Electric engine which has a completely different soun dto anything that Sulzer produced.Also beware that the TTS sound chip in the current Virgin HST which has MAN engines would not be correct for use in an original liveried HST which had Paxman Valenta engines.A quick search on you tube will help you identify teh diffenet sounds. Link to comment Share on other sites More sharing options...
pidder Posted January 12, 2017 Author Share Posted January 12, 2017 sultan thanks, shall have to think again, not an option at the present time then... Link to comment Share on other sites More sharing options...
