David S Posted January 12, 2017 Share Posted January 12, 2017 Hello, I am a newbie to this. I have a basic oval track and a Hornby Select controller. I want to control DS3 signal. Can the Select do this? If so can it do this directly or is an additional decoder unit required?Thanks,David Link to comment Share on other sites More sharing options...
David S Posted January 12, 2017 Author Share Posted January 12, 2017 Thanks for your reply. I hold down SELECT for 2 seconds and LA flashes. I set this to 61 , press select again and the red led above function flashes. Shorting the learn contacts on the signal makes the signal cycle RYG.Somehow I can now change from red to green with the > and < buttons but no yellow. The manual is not vey clear on all this! Link to comment Share on other sites More sharing options...
David S Posted January 12, 2017 Author Share Posted January 12, 2017 Ah, got it now thanks. One more question please, you said ensure you have nothing else on the track. Is that just to program the signal? Link to comment Share on other sites More sharing options...
David S Posted January 12, 2017 Author Share Posted January 12, 2017 I see, thanks very muc for your help.Dave. Link to comment Share on other sites More sharing options...
