RB51 Posted January 23, 2017 Author Share Posted January 23, 2017 Can I use two select controllers connected to my layout without conflict.? Link to comment Share on other sites More sharing options...
Rog RJ Posted January 23, 2017 Share Posted January 23, 2017 NO!!!! You must only have ONE DCC controller connected to the track at any time. You can connect 2 or more Selects together with an RJ12 cable though. Link to comment Share on other sites More sharing options...
96RAF Posted January 23, 2017 Share Posted January 23, 2017 I suggest you have a look in the Select manual breadboard - very clearly explained in there how its all done. Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 23, 2017 Share Posted January 23, 2017 To be clear, you can only connect one DCC controller to a track at a time. But a Select, connected to the track, can have a number of other Selects connected to it as Walkabouts. You need the correct cable and the Walkabouts connect only to the Select, not to a power supply and not to the track. Link to comment Share on other sites More sharing options...
