KNAP Posted January 26, 2017 Share Posted January 26, 2017 Edit program was working fine after latest update until last running session, when te buttn just turned grey and locked/ Also tried in offline mode with same result.Any ideas of possible cause or what can be tweaked? Link to comment Share on other sites More sharing options...
St1ngr4y Posted January 26, 2017 Share Posted January 26, 2017 Hi,The button should go grey after opening the editing window. Are you sure the editing window wasn't concealed behind the main window? Also, not sure what you mean by "offline mode". Can you elaborate please?Ray Link to comment Share on other sites More sharing options...
KNAP Posted January 26, 2017 Author Share Posted January 26, 2017 Usually edit program window appears over track plan, but it now appears as a window (hidden) but with no access (locked)..Offline Mode = Railmaster not connected to elink or layout. Link to comment Share on other sites More sharing options...
Chrissaf Posted January 26, 2017 Share Posted January 26, 2017 To bring a hidden window to the front (Windows PC....can't comment on iPads and Androids) press Alt + Tab key. Repeated presses of the Tab key whilst Alt is held will step sequentially through all windows that are open. Link to comment Share on other sites More sharing options...
KNAP Posted January 26, 2017 Author Share Posted January 26, 2017 Even when the window is selected it will not allow any access. Link to comment Share on other sites More sharing options...
St1ngr4y Posted January 26, 2017 Share Posted January 26, 2017 Even when the window is selected it will not allow any access.Do you mean that none of the buttons on the edit window work?Try recording a new program. When you have finished, RM will ask whether you want to edit it or not. If you say Yes, it will open the edit window with the recorded lines. See if this works or not.Ray Link to comment Share on other sites More sharing options...
KNAP Posted January 26, 2017 Author Share Posted January 26, 2017 Tested offline mode and the same thing happens with a new recording.My other laptop also has Railmaster installed and that edit button works fine. However, this is a minor update behind. Not sure whether to gamble with update and see what happens. Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 26, 2017 Share Posted January 26, 2017 I suggest you try Ray's suggestion to record a new program then try to edit it. When that has failed, email HRMS from the email in the Help window so they get your log.txt file and can see what happened. Do it from your copy which is latest, in fact download and update again from the link to make sure, because this will be first question they ask you. Link to comment Share on other sites More sharing options...
KNAP Posted January 26, 2017 Author Share Posted January 26, 2017 Downloaded updated and retried with Ray's suggestion.However log is showing following26/01/17 23:09:28 Recovering temoprary program26/01/17 23:09:29 Loading message window26/01/17 23:09:57 Message displayed: Would you like to recover the last program you were working on? (565) - Response=1 Link to comment Share on other sites More sharing options...
St1ngr4y Posted January 27, 2017 Share Posted January 27, 2017 RM does this if it is closed down (whether intentionally or not) while you are editing a program to which you have applied changes. During the editing process, a temporary amended file is maintained containing each change you make. It is deleted when your editing session is closed down normally. If the file still exists when you try to start up a new editing session, then you should see that message being displayed i.e Would you like to recover the last program you were working on? It sounds to me that you were not seeing this message on the screen and that the first time you knew about it was when you saw it in the log file? Ray Link to comment Share on other sites More sharing options...
96RAF Posted January 27, 2017 Share Posted January 27, 2017 That could explain why the edit button is greyed out as the edit facility is considerred to be still in use albeit maybe in error if the program didnt save and shut down properly. Link to comment Share on other sites More sharing options...
KNAP Posted January 27, 2017 Author Share Posted January 27, 2017 Uninstalled and re-installed cleared the problem. Thanks Link to comment Share on other sites More sharing options...
