Jazzonics Posted January 26, 2017 Share Posted January 26, 2017 Hi, Just a simple question? Should l be able to measure volts across the Track Output of the eLink when it is not connected to the track? My unit is receiving volts from the power supply but l have no output on the track terminals. Link to comment Share on other sites More sharing options...
Chrissaf Posted January 26, 2017 Share Posted January 26, 2017 YesMake sure the multi-meter is set to measure AC. You should get a reading of about 14.5 volts give or take a bit. Link to comment Share on other sites More sharing options...
