Spireblade Posted January 28, 2017 Share Posted January 28, 2017 One of my locos, Class 47TTS seems to have lost it's sound. All functions light up, the decoder seems to read and write normally. I have reset it to factory settings but still no sound. The loco runs beautifully. Could the decoder be knackered even though it works and programs correctly? Link to comment Share on other sites More sharing options...
96RAF Posted January 28, 2017 Share Posted January 28, 2017 A few things to try spireblade.1. resetting CV8 to value 5 - this will reset the sounds only, although value 8 should reset the whole thing.2. check if a speaker wire has come adrift.3. do a cold restart of RM to ensure it has reloaded that loco - even though it appears to work OK.Rob Link to comment Share on other sites More sharing options...
Spireblade Posted January 28, 2017 Author Share Posted January 28, 2017 Thanks Rob. I'll give it a go. Link to comment Share on other sites More sharing options...
Yelrow Posted January 28, 2017 Share Posted January 28, 2017 I have lost the sound, only to have it come back, on a re start of rm. john Link to comment Share on other sites More sharing options...
Spireblade Posted January 28, 2017 Author Share Posted January 28, 2017 All my other TTS loco's are working fine, I rebooted anyway and still have the problem with the 47 so I am currently trying Rob's solution. Fingers crossed Link to comment Share on other sites More sharing options...
Spireblade Posted January 28, 2017 Author Share Posted January 28, 2017 On looking again, I originally said that all the function lights were on. However only F1 for sound on/off will light.The wires all look to be in order to the speakerHaving reset CV8 to 5, it's still the same. Link to comment Share on other sites More sharing options...
96RAF Posted January 28, 2017 Share Posted January 28, 2017 I would go into loco setup in RM and just check the function listing there hasn't corrupted for some reason. If so just reinsert each function per the TTS manual listing or delete and relist that loco by R number. Link to comment Share on other sites More sharing options...
Spireblade Posted January 28, 2017 Author Share Posted January 28, 2017 I have tried reloading it by R number, that didn't work either!I'll fish out the function manual and have a look at that.I have also tried using the sound function buttons on my Elite, ......nowt. Cheers Link to comment Share on other sites More sharing options...
sparrow hawk Posted January 28, 2017 Share Posted January 28, 2017 HiI have had the same issue but with non TTS Decoder. Both times it was the speaker, that had failed swapped the speaker and all ok.Not sure if you can do this if it's still in waranty? Link to comment Share on other sites More sharing options...
Spireblade Posted January 28, 2017 Author Share Posted January 28, 2017 Unfortunately not under warranty....bought the loco on Ebay. ☹️ Link to comment Share on other sites More sharing options...
sparrow hawk Posted January 28, 2017 Share Posted January 28, 2017 You can get Speakers online from various DCC Shops .Not too expensive,but you will need to be able to solder the new one on.I am not sure what speaker they use on Class 47TTS ,you will find that someone mon the forum would be able to advise what one to go for, the watts and Ohm value. I think you should get a Speaker for around £5-£8 . Link to comment Share on other sites More sharing options...
2e0dtoeric Posted January 28, 2017 Share Posted January 28, 2017 As far as I know, they are all 8 ohm 1 watt. You sometimes find a pair of 4 ohm speakers wired in series (one after the other) to boost the noise levels. (2 x 4 = 8). Link to comment Share on other sites More sharing options...
Spireblade Posted January 29, 2017 Author Share Posted January 29, 2017 Having printed a list from the CV I have noticed that CV7 Manufactorer version is set to 005, which says Hornby TTS decoder (STEAM). Obviously the 47 is not a steam loco. Could this be the problem? Link to comment Share on other sites More sharing options...
Chrissaf Posted January 29, 2017 Share Posted January 29, 2017 Unlikely......Remember, it did work initially and now it has stopped. The suggested blown speaker is the most likely fault. TTS speaker failures have been reported on the forum many times. Link to comment Share on other sites More sharing options...
96RAF Posted January 29, 2017 Share Posted January 29, 2017 Try reading CV159 and see if you get value 149 if so you have a Class 47. Link to comment Share on other sites More sharing options...
Spireblade Posted January 29, 2017 Author Share Posted January 29, 2017 CV 159 is greyed out.....not used. CV158 loco type is value 000 Link to comment Share on other sites More sharing options...
Chrissaf Posted January 29, 2017 Share Posted January 29, 2017 CV159 is a 'read only' CV. So you can't write to it. You should still be able to read it though. I don't have any TTS locos so I can't confirm, but try going through the action of reading it and just see what happens. Link to comment Share on other sites More sharing options...
Spireblade Posted January 29, 2017 Author Share Posted January 29, 2017 No. Dosen't want to read it. Off to the repair shop with it then. Link to comment Share on other sites More sharing options...
Yelrow Posted January 29, 2017 Share Posted January 29, 2017 Is this not a Warranty matter. I would be talking to Hornby. john Link to comment Share on other sites More sharing options...
Spireblade Posted January 29, 2017 Author Share Posted January 29, 2017 Actually, it could be. I got this one from Peters Spares around 12 months ago.........not ebay as I first thought. I'll mail em.Thanks Link to comment Share on other sites More sharing options...
olly Posted January 29, 2017 Share Posted January 29, 2017 Sounds like the speaker has blown to me I've had a few go .There's plenty of room inside the 47 for a bigger speaker you will get much better sound quality too .I've just fitted a TTS hornby A4 with a zimo speaker sounds super Link to comment Share on other sites More sharing options...
Spireblade Posted February 1, 2017 Author Share Posted February 1, 2017 Well, problem solved.I decided to have a go at improving my soldering so I whipped out the speaker from another 47 and fitted it to the faulty one. Yep....it worked!!So....I thought I would try the offending speaker in the "good" 47......yes....it worked!!!!! so....errr......both are now working. It must have been a dry joint on the speaker or something similar. Link to comment Share on other sites More sharing options...
sparrow hawk Posted February 2, 2017 Share Posted February 2, 2017 That's Great News.Glad you managed to get your soldering practice , It really comes in handy in this hobby. And you get a lot of satisfaction when you solve a problem.Roy Link to comment Share on other sites More sharing options...
Spireblade Posted February 3, 2017 Author Share Posted February 3, 2017 OH the joy at having actually soldering something, and it actually working and looking neat. feeling all smug and pleased with myself. :-) Link to comment Share on other sites More sharing options...
Tardis4472 Posted June 26, 2017 Share Posted June 26, 2017 My Hornby king Richard II tts stop working entirel. So I was running it and then every single engine stop, just the two engines I was running. I find that there is a shortcircut, but where I take every thing off and find out that it is King Ricahard II. I try every thing until I found the decoder was the problem. I tried everything , I took a decoder from another engine and put in the king worked just fine. What is the problem? Link to comment Share on other sites More sharing options...
