86219 Posted January 28, 2017 Share Posted January 28, 2017 I have a TTS HST which has suddenly stopped working on my layout. It functions when placed on the programming track and I am able to change CVs and reset the decoder, but it is still unresponsive when placed back on the layout. Other DCC locos are still working correctly on the layout which is controlled by a Roco Z21. Any ideas on what the problem could be? Link to comment Share on other sites More sharing options...
96RAF Posted January 28, 2017 Share Posted January 28, 2017 Check that you have 128 speed steps set. Link to comment Share on other sites More sharing options...
86219 Posted January 28, 2017 Author Share Posted January 28, 2017 Thanks for the suggestion. I checked both controller and decoder and both were set to 128 steps but the power car was still unresponsive. I then removed the power car, turned it round and placed it back on the track and it started working, including sound. However, if placed back on the track in the original orientation it became unresponsive again. Rotating through 180 degrees again and the power car came back to life. Any idea why the orientation should make a difference? Link to comment Share on other sites More sharing options...
2e0dtoeric Posted January 28, 2017 Share Posted January 28, 2017 Mucky wheels, pick-ups, or track? Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 28, 2017 Share Posted January 28, 2017 Not surprised speed steps were 128 as you told us you reset the decoder and 128 is default. Which way around on the on the track makes no difference to DCC so agree with 2e0. Link to comment Share on other sites More sharing options...
