Fazy Posted February 18, 2017 Share Posted February 18, 2017 I bought a old Fowler 2-6-4t a few years ago. And a body which I converted to a limousine cab. I've Just bought a Xo3 motor to fit still needs brushes. But would like to fit the motor. However I would like to add a DCC chip. I was wondering what's a best way to go about it. The wires already fixed to the chassis seem to be just on one side, so either it's missing some or its directly feed from chassis to the motor. So how to isolate the motor and fit the chip would seem to be the question. Any help would be greatly appreciated. Link to comment Share on other sites More sharing options...
Fishmanoz Posted February 18, 2017 Share Posted February 18, 2017 X03/04 are the simplest of conversions. Usually for DC, the spring that holds the brushes has an insulating sleeve on one side and the return on the other side goes from brush to spring to motor to chassis to axles and uninsulated wheels. For DCC, just insulate the other side of the spring and now the motor is isolated from the chassis. Remove all connections to the brushes and discard the capacitor. Orange and grey decoder wires to the now insulated brushes, rail connections to the pickup wire on one side and to a connector under the bolt holding the motor on the other. And it's done. Link to comment Share on other sites More sharing options...
Fazy Posted February 18, 2017 Author Share Posted February 18, 2017 Cheers Fishmanoz. That sounds easy enough even for me. I was half expecting plastic screws and the like to be needed. What chip would you recommend using? Considering the amp difference between the old X03 and newer motors. Link to comment Share on other sites More sharing options...
Fishmanoz Posted February 18, 2017 Share Posted February 18, 2017 The answer is it depends and always best to do a stall current test to be sure. Some have reported success with the 8249 on these motors but I'd feel much safer using a 1Amp decoder rather than the 8249 with 500mA. That would mean a Sapphire or another brand. Link to comment Share on other sites More sharing options...
geoff77 Posted February 22, 2017 Share Posted February 22, 2017 for rail connections, read black & red wires on decoder Link to comment Share on other sites More sharing options...
