Chrissaf Posted February 23, 2017 Share Posted February 23, 2017 Many users on here use RailMaster & eLink on Windows 10 without any issues. Some users do have issues, but these are usually resolved by correctly configuring RailMaster and their PC. It is true to say, that running RailMaster & eLink on Windows 10 is not 'Plug n Play' and does require a significant amount of setting up to be reliable..This is the reason that there are two sticky posts at the top of the forum RailMaster & TrackMaster section (see image below). These two sticky posts between them, document all the help most people need to get their Windows 10 system correctly configured for RailMaster../media/tinymce_upload/a3f9eafef760dd4cf9aceb330cc2c307.jpg.The single most common reason Windows 10 users get communication errors (controller / USB not recognised) with eLink is because they haven't got the following two lines in their "railmaster.ini file":.Alternative comms=1Check controller=1.Adding these two lines to the end of their .INI file resolves the majority of eLink communication errors. See the second sticky in the image I posted (RailMaster: Setting Up and Getting Started) and look for the section relating to Windows 10 in it for further details. Link to comment Share on other sites More sharing options...
Chrissaf Posted February 23, 2017 Share Posted February 23, 2017 Dos windows 10 run well wil elink and the railmarster software 1.65 like do there hand shack as it's cold to get the trains running I know it's a bit odd asking sorry Link to comment Share on other sites More sharing options...
