Keep front lights on in both directions
paul.b
Hi all
I have fitted front oil lamps to my A4 mallard which work great is there a cv setting to keep the front lights on in both directions.I read somewhere there is a cv setting to do this but i cant find it anywhere
Thanks in advance .....paul
Its a tts model if that makes a difference r3395 tts i think
You cant remap functions on a TTS decoder so it would be a case of adding a link on the decoder socket to join pins 2 and 6.
For a quick one-off you could bridge the decoder plug pins with a link rather than lift the socket again.
Then no matter which direction you are going the front lights will be on.
No good if you have rear lights as both ends will be on at once in both directions.
Rob
/media/tinymce_upload/430d4d7be1c99a2c03605c7725ab35f8.jpg
