Potrail2378 Posted March 1, 2017 Share Posted March 1, 2017 Hi guys, just a quick question. Is it possible to secure a Hornby select to the top of a baseboard via screws/nuts & bolts? Or should I just use something like blue tack? All I want to do is stop it from sliding about. Thanks in advance ☺️ Link to comment Share on other sites More sharing options...
walkingthedog Posted March 1, 2017 Share Posted March 1, 2017 There is always a way. Make a frame for it to sit in. Link to comment Share on other sites More sharing options...
Yelrow Posted March 1, 2017 Share Posted March 1, 2017 Double sided tape ?. john Link to comment Share on other sites More sharing options...
dynax Posted March 1, 2017 Share Posted March 1, 2017 self adhesive velcro, then you can move it if you need to, Link to comment Share on other sites More sharing options...
walkingthedog Posted March 1, 2017 Share Posted March 1, 2017 Make a frame AND choose one if the other two. Link to comment Share on other sites More sharing options...
96RAF Posted March 1, 2017 Share Posted March 1, 2017 I'm sure we had this exact same question many moons ago ref securing the Elite to a board.And it got the same answers. Link to comment Share on other sites More sharing options...
Potrail2378 Posted March 1, 2017 Author Share Posted March 1, 2017 Thank you for answers. I actually forgot to mention that the spare piece of baseboard (on which all my sockets, switches, etc) is going to be at around a 45 degree angle, sloping towards me. Link to comment Share on other sites More sharing options...
walkingthedog Posted March 1, 2017 Share Posted March 1, 2017 Definitely as stated then. A frame like a picture frame plus tape or velcro. 😆 Link to comment Share on other sites More sharing options...
Class 08 Posted March 1, 2017 Share Posted March 1, 2017 This is what I've done, I will be adding an elite with this as well soon/media/tinymce_upload/fed2611bf2681cf860142a9df041fc54.JPG Link to comment Share on other sites More sharing options...
Class 08 Posted March 1, 2017 Share Posted March 1, 2017 /media/tinymce_upload/0c5059252b7485ab6faaf80dc15ce089.JPG Link to comment Share on other sites More sharing options...
2e0dtoeric Posted March 2, 2017 Share Posted March 2, 2017 Class 08 - you have nearly as much 'junk' under your boards as I do! 😛 Link to comment Share on other sites More sharing options...
Class 08 Posted March 2, 2017 Share Posted March 2, 2017 Class 08 - you have nearly as much 'junk' under your boards as I do! 😛Haha, that's just one small section! This weekend I'm planning on having a big tidy up! It's amazing how much junk gets collected so quick. Link to comment Share on other sites More sharing options...
96RAF Posted March 2, 2017 Share Posted March 2, 2017 I would 'triangle' the ends as well 08. Link to comment Share on other sites More sharing options...
Class 08 Posted March 2, 2017 Share Posted March 2, 2017 I would 'triangle' the ends as well 08.I don't understand what you mean? Link to comment Share on other sites More sharing options...
Chrissaf Posted March 2, 2017 Share Posted March 2, 2017 He means add a triangular fillet on the ends of the flat panel so that the controllers can't slide sideways off the shelf../media/tinymce_upload/671071a09736e34f7c07c4d7701f322f.jpg. Link to comment Share on other sites More sharing options...
Class 08 Posted March 2, 2017 Share Posted March 2, 2017 Thanks chrissaf, my mind went blank. I will but wanted to wait till I got my Elite. Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 2, 2017 Share Posted March 2, 2017 I have no problem with my Select sliding around, it stays exactly where I put it in the bottom draw even when I tip the chest up 60 degrees! Link to comment Share on other sites More sharing options...
96RAF Posted March 3, 2017 Share Posted March 3, 2017 I have no problem with my Select sliding around, it stays exactly where I put it in the bottom draw even when I tip the chest up 60 degrees!We will miss your anti-Select banter Fishy when you eventually get round to sending it to John in France.Rob Link to comment Share on other sites More sharing options...
trainlover23 Posted March 3, 2017 Share Posted March 3, 2017 A couple of 6" nails through it normally does the trick Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 3, 2017 Share Posted March 3, 2017 Don't forget to drill oversize holes in the buttons you put the nails through tl, else they'll stick. Therell always be a space in my bottom drawer to refer to Rob, even if its previous occupant is abroad. Link to comment Share on other sites More sharing options...
