help needed with network southeast class 423
SABBYLUDA
hi all,
i have just bought a network southeast class 423 4vep dcc ready not fitted and i am finding that which ever direction it travels in the first two wheels on the first bogie are derailing on every corner, i am not sure if the bogies dont turn enough or if it is a lack of weight on the leading wheels.
has anyone else had this problem and if so how have you resolved it?.
many thanks
russ.
Hi Russ and welcome to the Forum
Did you buy the Loco new, because if you did, it should rule out any mechanical problems that are causing the de-rail.
What radius curve are you having problems with as a lot of Loco's do not like 1st radius.
