mikejj101 Posted March 27, 2017 Share Posted March 27, 2017 I have aquired from a local carboot sale a Hornby DCC set which includes a model of R1077 4-6-0 Windsor Castle along with an 0-6-0 tank engine.Both engines appear in the engine list of eLink but when I attempt to read the decoders fitted in these engines I get a message back from eLink that the decoders do not exist in the database. I have managed to write an ID address to the decoders which allows them to run but I cannot get eLink to read the decoders at all. I get messages suggesting why they cannot be read but nothing I do changes the fact that they cannot be read. All my other locos decoders read OK.The performance of these engines is very erratic. I've tried writing to CV3 & CV4, setting the acceleration/deceleration rates to 005 - not much changes - they both tear away at random times and then at other times hardley move.Both decoders are small 4 pin devices - well actually it's a 4 socket - the pins are on the loco loom.To overcome these issues I tried fitting one of the new Hornby Pecket decoders - which believe it or not work a treat. They are the exact same size and pin config. Costing only £12.00 each - it's quite a cheap repair job. They now work fine.Thought I would post this on here as it may be of interest to anyone else who has the same Windsor Castle loco. Link to comment Share on other sites More sharing options...
96RAF Posted March 27, 2017 Share Posted March 27, 2017 I would have recommended a decoder reset - I.e. Write value 8 to CV8' but you seem to have solved the problem by substitution. I wonder if the early 4-pin decoders were reworked old stock R8215 dodgy decoders, fit only for the bin. Link to comment Share on other sites More sharing options...
mikejj101 Posted March 27, 2017 Author Share Posted March 27, 2017 I would have recommended a decoder reset - I.e. Write value 8 to CV8' but you seem to have solved the problem by substitution. I wonder if the early 4-pin decoders were reworked old stock R8215 dodgy decoders, fit only for the bin.I did try writing value 8 to CV8 but that made no difference to the way the decoder worked.The old decoders are where you suggested they should be !Cheers Link to comment Share on other sites More sharing options...
samfieldhouse Posted March 29, 2017 Share Posted March 29, 2017 A top tip. This was my first digital set from which all else was born. I've recently rebuilt the motor in the castle, I wonder if a new/better chip could help. Are the pecket decoders available online? Link to comment Share on other sites More sharing options...
ff2nd Posted March 29, 2017 Share Posted March 29, 2017 Not surprising the Peckett chip is the same size and config. It's the same chip. X9659 has been around for years. Link to comment Share on other sites More sharing options...
