in-training Posted April 3, 2017 Share Posted April 3, 2017 Could do with some advice on DCC select controller when I connect to track 3 lines come up on the dash any suggestions on what is going please.I can connect to dc and run dc trains on track no problem. With track not connected I can work the points Link to comment Share on other sites More sharing options...
Fishmanoz Posted April 3, 2017 Share Posted April 3, 2017 Hi in-training, welcome to the forum. I'm not sure I understand exactly what you mean with your question, however DCC is connected to the track via the A and B track outputs on your Select using a DCC (not DC) power track or power clip or other direction connection like soldering to the track. This is the same as with DC where again the 2 track outputs go to the track. Just one thing to note, you cannot connect both DCC and DC at the same time, they must be completely separate with only one DCC controller connected at the same time too. Link to comment Share on other sites More sharing options...
in-training Posted April 4, 2017 Author Share Posted April 4, 2017 I will try to explain better When I connect the a & b wires to the track layout the controller seems to shut down 3 lines appear on the screen and nothing works I have hooked it up to a short piece of track not connected to the layout and it works fine.I hooked up the dc after removing the dcc and i can run a dc train on the track no problem Thats sort of tells me there is no shorts any idea whats going onMany thanks Link to comment Share on other sites More sharing options...
Howbi Posted April 4, 2017 Share Posted April 4, 2017 @in-training.........Derek, may I suggest you type your reply in the 'Reply' box at the bottom of this page rather than use the blue 'Quote' symbol......... 😀............HB Link to comment Share on other sites More sharing options...
Chrissaf Posted April 4, 2017 Share Posted April 4, 2017 Are you using the DCC power track connector and NOT your previous DC Analogue power track connector?The DC version is not compatible with DCC. Link to comment Share on other sites More sharing options...
Fishmanoz Posted April 4, 2017 Share Posted April 4, 2017 It seems you have a short circuit on your track. These are often caused by having made a reversing loop somewhere. If you can post a picture or diagram of your layout we can advise further. Link to comment Share on other sites More sharing options...
in-training Posted April 5, 2017 Author Share Posted April 5, 2017 Hey Thanks for your help .I have found the problem it is one of the turn points when you switch it over it shorts out. Just got to work out how to fix it. This track was started by a friend and another guy who was an intruments tech who passed away about 18 months ago since then it has been sitting in shed. No doubt I will needing more advice as i go Thanks again Link to comment Share on other sites More sharing options...
Fishmanoz Posted April 5, 2017 Share Posted April 5, 2017 Glad you are getting the it. If you can tell us what type of point it is, brand, part number, even insulfrog (plastic frog) or electrofrog, we may be able to help more. Link to comment Share on other sites More sharing options...
in-training Posted April 9, 2017 Author Share Posted April 9, 2017 Hi Found the problem was simple enough had to lift some track and add a plastic fish plate to the electrofrog turn out. Now I have got to get my locos dcc chipped any advice on type make of chip would be very helpfullThanks from in-training....Southern all the way :) Link to comment Share on other sites More sharing options...
