Mike42 Posted April 10, 2017 Share Posted April 10, 2017 Hello, I have two Bachmann steam locos, a 4-6-0 Manor Class and 4-6-0 Rebuilt Patriot Class.Which of the new TTS sound decoders would be closest to teh actual sounds of these locs?Thanks very much for your help Link to comment Share on other sites More sharing options...
2e0dtoeric Posted April 10, 2017 Share Posted April 10, 2017 Perhaps neither!Bachmann loco's usually have a 21 pin socket, and Hornby's TTS are 8 pin.You would probably need an 8 to 21 adaptor, as well, and it depends if there is enough room inside! Link to comment Share on other sites More sharing options...
Percybigun Posted April 11, 2017 Share Posted April 11, 2017 The fowler 2p lms TTS decoder is a good choice, the bachmann 8 to 21 pin adaptor is only £3.50 and this setup works perfect and fits easy in my bachmann midland compound (Which has tender mounted dcc socket). I also find the fowler 2p decoder is far superior soundwise and control-wise than the A4 and A3 tts decoders so i'll use it in most future conversions. Link to comment Share on other sites More sharing options...
Fazy Posted April 11, 2017 Share Posted April 11, 2017 Bachmanms rebuilt patriot Is a pre DCC model. Link to comment Share on other sites More sharing options...
Fishmanoz Posted April 11, 2017 Share Posted April 11, 2017 Even pre-DCC, you can still fit it by hard wiring it in, then you won't need the adaptor either. Not that using an adaptor is a problem as 2e0 implies. Shouldn't you be looking to use a TTS for a loco with the same cylinder configuration as the one you are putting it into? That way, the chuff rate should be correct. The fact it's Bachmann is irrelevant in this, only what type of loco it is. There are lots of other threads covering this aspect. Try a forum search on chuff or chuff rate. Link to comment Share on other sites More sharing options...
Fazy Posted April 12, 2017 Share Posted April 12, 2017 The rebuilt patriots are 3 Cylinder beasties. So getting a match within the Hornby range might be a bit of a problem at the moment. I know that hornby do both of the green re-built Staniers. However I am unsure if they have done TTS for them yet. Which is the one you will need when available. And i would think hornby will do these in the future as the re-builds have become a Hornby staple over the past decade. So if you can wait I would suggest that you do for now. As for your BR standard all BR standards werr 2 cylinders. Link to comment Share on other sites More sharing options...
96RAF Posted April 12, 2017 Share Posted April 12, 2017 A4 is a three cylinder loco. Link to comment Share on other sites More sharing options...
Howbi Posted April 12, 2017 Share Posted April 12, 2017 The TTS decoders available for pre-order are:-.........3 cylinder engines - A3, A1, A4 and for 4 cylinder engines - King class, Castle class.........TTS for 2 cylinder engines are fitted in a 2P and a 9F but these may only be available separately when a retailer splits from a fitted model.........Hopefully Hornby will also release these for separate purchase in due course...........HB Link to comment Share on other sites More sharing options...
2e0dtoeric Posted April 12, 2017 Share Posted April 12, 2017 Fishy put - using an adaptor is a problem as 2e0 implies. - I wasn't meaning there was a problem with using the adaptor - only that there might be a problem with the available space! Link to comment Share on other sites More sharing options...
Fishmanoz Posted April 12, 2017 Share Posted April 12, 2017 I was responding to your perhaps neither comment 2e0, agree on the space though. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted April 12, 2017 Share Posted April 12, 2017 😆 Link to comment Share on other sites More sharing options...
Fazy Posted April 13, 2017 Share Posted April 13, 2017 I would think if anyone wanted to chip a split chassis rebuilt Stanier the tender would be the best place to fit the chip and speaker. (As the chassis is a big lump)obviously With wires between the tender/ loco. Link to comment Share on other sites More sharing options...
Fishmanoz Posted April 13, 2017 Share Posted April 13, 2017 You still have to isolate motor from chassis, which has always been the split chassis problem? Link to comment Share on other sites More sharing options...
Fazy Posted April 13, 2017 Share Posted April 13, 2017 Yep though there's some good articles on the problem. I have a old Bachmann Jubilee which uses the same chassis as the rebuilds which I will have to convert one day Link to comment Share on other sites More sharing options...
81F Posted April 16, 2017 Share Posted April 16, 2017 Yep though there's some good articles on the problem. I have a old Bachmann Jubilee which uses the same chassis as the rebuilds which I will have to convert one dayMe too and a Scott as well - something I keep putting off and off and off...! Link to comment Share on other sites More sharing options...
