How to power up eurostar dummy car for lights
Schuie52
I don't have a Eurostar and the service sheets (DCC ready and non DCC) are not as clear as they could be, but as you have had no replies so far let me throw this suggestion into the ring.
I would look at the power car to see if the leading bogie has pickups (it seems to have wires to it). Then compare chassis fittings to see if it would fit in the dummy car in lieu of the standard bogie, then its a case of wiring in a socket per the usual pattern and colours, then wire in the lights following the standard logic from the socket.
If that plan looks good then that would give you a parts list of a decoder socket and a leading bogie from the power car and some wires, plus the lights, either using power car parts or your own leds and resistors.
Rob
