glen245 Posted April 21, 2017 Share Posted April 21, 2017 can someone help me how do you keep your colour light signals on using the hornby accessory decoder kind regards glen Link to comment Share on other sites More sharing options...
96RAF Posted April 21, 2017 Share Posted April 21, 2017 You look in the instructions to see how to set the output to continuous, instead of pulse. This only applies to the R8247 acc decoder not the earlier R8216 which is pulse only. Link to comment Share on other sites More sharing options...
glen245 Posted April 21, 2017 Author Share Posted April 21, 2017 You look in the instructions to see how to set the output to continuous, instead of pulse. This only applies to the R8247 acc decoder not the earlier R8216 which is pulse only.there is no output only cv the signal stays on for 40 s then goes out i want the signal to stay on permantly changing the signal is fine and when you push the button to change signal it switches back on if you know where or how to set the output please advise cheers Link to comment Share on other sites More sharing options...
St1ngr4y Posted April 21, 2017 Share Posted April 21, 2017 Hello Glen,You don't mention which DCC controller you are using, or whether or not you are using Railmaster. However, you need to set CV3 or 4 or 5 or 6 to zero depending on which port of the R8247 the signal is connected to...../media/tinymce_upload/8d5629b3c22e1fc26c5803ed1e29859f.pngThe top picture shows how to do it in Railmaster, the one below shows the CVs relating to each port of the R8247. Hope this helps. Ray Link to comment Share on other sites More sharing options...
