Retrojim Posted April 23, 2017 Share Posted April 23, 2017 Im trying to plan a new layout using Hornby track. Im hoping to create four oval lines but my space is impeded by pipes which I need to work round. Can soneone please tell me if I am on the right lines (picture below) with each radius and what do I need to complete the forth line./media/tinymce_upload/727a24dfe684f70e05273498e4ba46a5.jpg Link to comment Share on other sites More sharing options...
Rog RJ Posted April 24, 2017 Share Posted April 24, 2017 You could use flexitrack, in fact all of those curves could be done with flexy. Link to comment Share on other sites More sharing options...
Class 08 Posted April 24, 2017 Share Posted April 24, 2017 I agree with rog, flexi track would be good! Link to comment Share on other sites More sharing options...
walkingthedog Posted April 24, 2017 Share Posted April 24, 2017 Me too. Link to comment Share on other sites More sharing options...
Jeff Mennell Posted April 24, 2017 Share Posted April 24, 2017 I recently used a load of flexy for the first time and was pleasantly surprsed with the results. Not as difficult to install as I imagined and it comes in big long sections. Bought mine second hand but am I right in thinking that when new it is cheaper than set track? Link to comment Share on other sites More sharing options...
walkingthedog Posted April 24, 2017 Share Posted April 24, 2017 Yes cheaper. The longest set track straight is about 26 inches and a length of flexi about 36 inches. Both are the same price. Curves work out even dearer. Link to comment Share on other sites More sharing options...
Jeff Mennell Posted April 24, 2017 Share Posted April 24, 2017 I wonder why folk don't just buy flexi (with track templates say), when constructing larger layouts? Less joins etc Would be a lot cheaper....almost seems to good to be true? Link to comment Share on other sites More sharing options...
walkingthedog Posted April 24, 2017 Share Posted April 24, 2017 I agree but on my layout if I need a 4th rad curves I'll buy Peco set track. Easier to lay in areas where you need to stretch across the layout. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted April 24, 2017 Share Posted April 24, 2017 Apart from the points - Peco Express - all my track is either flexi or semi-flexi, dependng on what was to hand at the time! Flexi is easier on full curves, but semi-flexi is good for little wriggles around scenery - but someone is bound to say the reverse is true! :-) Link to comment Share on other sites More sharing options...
96RAF Posted April 24, 2017 Share Posted April 24, 2017 You need to do the 'pencil taped to a long carriage' check at the smallest radius inner curves to check for adequate clearance around that obstruction first then space out the other lines to suit from that datum line. Link to comment Share on other sites More sharing options...
